Go to Post According to that logic, Engineers would say there will be twice as many spectators as needed, and we all know that's not the case! - Taylor [more]
Unread 06-02-2016, 16:14
Nikolas Untoten Nikolas Untoten is offline
FRC #3219
Nikolas Untoten is an unknown quantity at this point
Unhappy Problem with the SmartDashboard
Recently our SmartDashboard is having issues. The data we request from the robot is not returning anything. We are able to write to the SmartDashboard, and the dashboard is connected to the robot. Any help would be appreciated.
Unread 06-02-2016, 16:22
jajabinx124's Avatar
jajabinx124 jajabinx124 is offline
Team 2052 Alumnus
AKA: Kshitij Wavre
jajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond repute
Re: Problem with the SmartDashboard
What type of data are you guys requesting from the robot? Sounds like the SmartDashboard may not be the problem.. maybe it's whatever data you guys are requesting (sensor feedback, etc.)
FRC Volunteer CSA (MRI off-season event, 2017 Lake Superior Regional, 2017 10,000 Lakes Regional) 2016 - Present
FRC 2052 KnightKrawler (Team Captain, Strategist, Scouting, Programming) 2013 - 2016
1 Division Win & Einstein Appearance
3 Division Quarter-Finalists
1 Regional Chairman's Award
5 Regional Wins, 3 Regional Finalists
3 MN State Championship Wins, 1 MN State Championship Finalist
Thanks to all our alliance partners who krawled with us: 41, 70, 225, 525, 1595, 2054, 2062, 2122, 2175, 2227, 2472, 2526, 2883, 2990, 3018, 3244, 3276, 3310, 3313, 3360, 3538, 3692, 4011, 4198, 4536, 4607, 4778, 5172, 5690
Unread 06-02-2016, 16:41
FRC #3219
We are Requesting the data from one lidar, and one ultrasonic. The types of data we are requesting is the voltage of the ultrasonic, which is then converted into a distance by using a calculation. For the lidar, we are requesting data through the lidar.read(), which should return bytes.
Unread 06-02-2016, 17:01
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Sensors have nothing to do with SmartDashboard. You read those from the DIO/AIO ports.
Unread 06-02-2016, 17:47
Team 2052 Alumnus
AKA: Kshitij Wavre
Right, but in his case the SmartDashboard is connected to the robot and they are able to write to the SmartDashboard which I think eliminates that the SmartDashboard is the issue in this case..? Maybe it's the sensors that are not properly sending values and that's why the values aren't changing..
Unread 06-02-2016, 18:02
If the sensors are not reading, some problems may be:
1) Sensor is not wired correctly
2) Sensor not connected to roborio correctly
3) Sensor class not properly created
4) Provided wrong port number to the sensor class
5) Not using the sensor class correctly to read the value.
6) Sensor is broken
Unread 06-02-2016, 18:33
Team 2052 Alumnus
AKA: Kshitij Wavre
6) Sensor is broken
Improper voltage to distance calculations may also cause that.. you never know some simple math could be the problem.
