Go to Post Overall... the secret is PROTOTYPING! Design is an iterative process. Do some basic design in your head. Build it. Test it. Improve it. Repeat until satisfied. - JVN [more]
Unread 06-02-2016, 16:11
Humberto fig's Avatar
Humberto fig Humberto fig is offline
FRC #4735 (DEROF)
Humberto fig has a spectacular aura aboutHumberto fig has a spectacular aura aboutHumberto fig has a spectacular aura about
pic: Custom drivetrain
Unread 06-02-2016, 16:12
Re: pic: Custom drivetrain
OK, I'll bite on this one:
My first thought was "What about bumper supports?"
Unread 06-02-2016, 16:13
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
How is the back wheel held in? I see axles and nuts on the front two...
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 06-02-2016, 17:07
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
Are those stretched-out bike tires?
Unread 06-02-2016, 17:17
FRC #4735 (DEROF)
We have already solved the bumper issue, but we want to see if you find any restriction on it.
Unread 06-02-2016, 17:19
FRC #4735 (DEROF)
its directly connected to the motor, that is what its holding it
Unread 06-02-2016, 17:20
FRC #4735 (DEROF)
yes they are.
Unread 06-02-2016, 17:23
Might want to show your solution. What I'm seeing is an articulated frame perimeter (something about the tracks being beyond the frame, and forming the perimeter).
Unread 06-02-2016, 18:46
Cool idea, how well does it work? What size are those wheels? For that matter, what are those wheels? What gear ratio are you running?
Andrew Basse
Unread 06-02-2016, 19:30
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
My first thought upon seeing any novel tank tread solution is to wonder whether the treads are going to fall off the pulleys. In your case, I'm also wondering how much effective traction you're going to have, since you're limited by the metal-rubber coefficient of friction instead of knobby rubber-carpet.
Unread 06-02-2016, 20:33
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Is the entire system running off of just 2 CIMs (1 on each side), and are those planetary gearboxes they're driving (if so, what reduction)?
My biggest concern, in addition to the one mentioned above about getting enough traction, is whether or not you'll be able to turn at all with this. Generally the scrub on a high traction drive requires teams to use at least 4 CIMs on their drive system to avoid stalling their motors when attempting to turn.
Unread 06-02-2016, 20:59
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Have you driven it under full robot weight yet? Usually ~150lbs.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 06-02-2016, 21:01
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
I would expect that there is a CIM on each of the front and back "wheels/pulleys".
Unread 06-02-2016, 21:31
cbale2000's Avatar
AKA: Chris Bale
If there is a CIM in the back, it would appear to be driven differently than the one in the front, as there is a threaded rod supporting the back wheel but not the front.
Unread 06-02-2016, 22:01
pilleya's Avatar
Elec+Mech
It looks like your correct, so if this is the case and it is only 2CIM, then it will be interesting, that means that there is also 1/2 the friction area of the pulley against the tread, that I thought that there was. It looks like a BB 220 gearbox and while it is a rugged gearbox Banebots says " We recommend using a design that supports the end of the shaft", probably isn't a huge problem here as the wheel is close to the face, but something to be aware of
