Go to Post DonRotolo used COMMON SENSE. ... ... FIRST/Chief Delphi Community fainted! - PayneTrain [more]
Unread 06-02-2016, 21:14
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Re: PNP versus NPN sensors
Originally Posted by Kevin Sevcik View Post
An important caveat is that this only works with 5V PNP sensors. A 12V PNP output is going to blow up your DIO port unless you use a more complicated circuit.
The roborio is not the digital side car. Per specs, the DIO ports can take up to 16v. They were designed with being able to take 12v in mind.
