Re: Rhino track failier?
It's a new product this year and as with any new product there are going to be problems. Especially for a complicated system like a tank tread system, teams spend many seasons and off-seasons trying to perfect their design. It seems that the pulleys, are the same type of material as the Hi-grip wheels, and there is barely any material to cushion any impacts. With the impacts that tank treads will receive in this years game, it seems that maybe plastic just isn't fit for this purpose and maybe Aluminium Pulleys would be better( at a significant monetary cost).
I'm sure that the guys at Andymark, are doing their best to find a solution to this problem. It seems that due to the dead axle design, it would be quite simple and quick to change out broken pulleys, especially driven ones and replacements aren't too expensive either $8 Last edited by pilleya : 06-02-2016 at 22:31. |
The belt is also steel-reinforced so there wouldn't be any stretch at all, and also the belt isn't going to slip. This isn't something that can be fixed by loosing off the belt tension either, because as soon as the belt is loosened, it'll be taken off by another robot extremely easily |
So if it is a steel reinforced belt then how can it be a spliced endless loop belt, surely the weak point would be the splice? It seems difficult to join the steel strands, while they are embedded in the belt, because any heat welding would melt the rubber belt. So it is a crimp or something that is used to join the strands? |
the steel cable will stretch over time if under constant pressure, my team did some testing last night and as long as you cant pull the track off the system by yourself they should be fine. track tension is not the main source of the problem but over tightening is definitely not helpful. (PS has anyone actually contacted AM yet?)
-thanks |
#8
Do you have any fresh wheels to measure the bearing hole size prior to pressing a bearing in?
Since you have the problem I would reccomend that you contact Andymark so you can discuss the exact conditions that caused the failure. You are the team that knows the details and can answer questions as they are asked pertaining to the failure. That will be better and faster than another team searching for answers without having all the information in front of them. |
#9
My team is not meeting on Sundays but tomorrow i will make sure that we contact AM, i do not want to start negotiating without having the parts in Question in front of me.
#10
We are talking about replacing them with aluminum. Glad we found it before any competitions! It makes me wonder about all the other teams using them who don't know or haven't had issues yet.
#11
Anyone want to place bets on the tool maker deciding to put a draft on that bore without telling anyone at Andymark? |
#12
That was my thought when I posted that... it should be noticeable if it's there. What's a standard draft? In college we did 2.5 degrees, but we were a bunch of noobs when it came to making a mold.
#13
I wonder about the fillet at the bottom of the bearing pocket in conjunction with clamping loads from a traditional dead shaft configuration.
#15
Thought I'd do some research, since I recall similar problems:
http://www.chiefdelphi.com/forums/showthread.php?t=84560&page=3&highlight=wheel+crac king http://www.chiefdelphi.com/forums/sh...ht=wheel+crack http://www.chiefdelphi.com/forums/sh...wheel+cracking Most of the reports were from heavy shock loading from running into the old rock-wall like bump. Some were from applying loctite, which as noted in this thread, eats polycarb alive. Some reports were from over-tightening sprocket or assembly bolts. I think atleast one person blamed killing plaction wheels on hammering/forcing bearing into the wheel instead of hand pushing them in and stopping wherever they tightened up. Not saying any of these are the are the actual solution, just putting it up to inform the speculation. |
