Go to Post Someone once said, "I know what finished is, and I know what a robot is, but what is this finished robot you speak of?" - EricH [more]
Unread 02-06-2016, 10:41 PM
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: PNP versus NPN sensors
Could a simple (and quite inexpensive) NPN transistor be made to work?
Originally Posted by Kevin Sevcik View Post
I'm hesitant about that without my Art of Electronics to remind me about transistor fundamentals. I think that's alright, but you should have high values for the resistors. Probably dividing down till the base voltage is less than 3.3V. If I remember correctly, an NPN has a diode from base to collector which would be forward biased if you drive the base with more than 3.3V. Which I think would be bad, or atleast wouldn't work properly.
You can use an NPN BJT with a single series resistor of high enough resistance to limit the base current. I don't think the voltage divider is necessary.
You can also use a FET with a pull-down resistor on the gate. This is what I would pick. The resistor value doesn't matter, as long as the current through it isn't higher than the limit for the PNP in the sensor.
Kettering Motorsports
