Go to Post These folks have bigger hearts than most. I think they grow them that way in Indiana. - JaneYoung [more]
Unread 07-02-2016, 13:51
ICE_Bear ICE_Bear is offline
FRC #5875 (ICE)
ICE_Bear is an unknown quantity at this point
Re: Bumper Rules on a U Bot Chassis
Wouldn't you just have to cover the entire piece that IS there? per R19
Unread 07-02-2016, 13:58
MrBasse MrBasse is online now
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Read the sentence just before the one you are thinking of in R19 and you'll see why you need at least 8" covered.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 07-02-2016, 14:00
GaryVoshol's Avatar
GaryVoshol GaryVoshol is online now
Cogito ergo arbitro
That's not how "side" is defined. The side is from outside corner to outside corner, including any gaps that happen to be in that side. See ROBOT FRAME PERIMETER C (lower left) in Figure 4-3. The FRAME PERIMETER follows the black line around the ROBOT, including the portion spanning the gap. It is marked "NOT OK" since that bottom "U" is less than 8 inches.
(since 2004)
Unread 07-02-2016, 14:20
FRC #5875 (ICE)
That was labeled "NOT OKAY" because the corner wasn't covered, not because it was less than an 8" piece of the side.
Since it's our chassis piece that's only 4.5 inches long, wouldn't each individual piece be a side?
Unread 07-02-2016, 14:30
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
There are two "NOT OK" labels for Figure 4-3 C - one for an uncovered corner, the other for a segment <8".
You are receiving replies from experienced mentors and robot inspectors, you should consider how to address your design issue. If you are not satisfied with the responses from CD, you should post on FIRST Q&A for official clarification.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 07-02-2016, 14:39
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Its fairly simple to determine what size bumpers you need.... use walls and string
Place your robot against wall (without bumpers) that defines a side THEN for each side at least 8 in. of BUMPER must be placed on each side of each outside corner. IF a side is less than 8" entire side must be covered.
So for a U shaped bot the front side would require 8" bumpers per front corner. Thats assuming traditional U-shape with two front corners.
For odd shapes... or to verify corners
Simply wrap a string around the bot (in bumper zone)..any corner of that string shape (frame perimeter) needs an 8" bumper per outside corner side. So its hard to get around 8" rule even with very unique shapes. Either each comer needs 8" bumper side or the entire side <8" needs a bumper, your choice. Anything inside the frame perimeter shape does not need a bumper.
Your extension zone is now 15" beyond original frame perimeter with same shape.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star #21 | Galileo Division #91
Unread 07-02-2016, 15:57
Don't rely on pictures, READ the rules. If you just look at pictures you'll never get the whole story.
Earlier you referenced r19. Read r19. Then re-read r19 just to be sure. I'm on my 7th time through the full manual plus all the other times I have check little items in between. If you read it you'll get your answer and notice every side that is less than 8 inches must be fully covered. You'll also see that you need a minimum of 8 inches covered from each corner.
Andrew Basse
Unread 12-02-2016, 10:59
mastachyra's Avatar
mastachyra mastachyra is offline
FRC #2781 (RoboPride)
mastachyra is just really nicemastachyra is just really nicemastachyra is just really nicemastachyra is just really nice
Word of this change needs to be spread more loudly, or many teams are going to have a major issue at competition. Our robot has been driving and picking up balls for two weeks and now we need to widen our chassis. This is a huge waste of time.
I'm currently looking at the rules we printed out on kickoff day, and this rule is unclear. I guess I interpreted the words "side" and "frame perimeter" to mean different things. The frame perimeter was clearly an imaginary line around the robot, but I took "side" to mean a physical side of the robot.
It was especially confusing because the rules say "If a side is shorter than 8 in., the entire side must be protected by BUMPER"
I can take a picture of the old figure 4-3: BUMPER Corner Examples if anyone is interested.
2014: EtaBot - MWR/30th place/no PO
2015: ThetaBot - MWR/30th place/no PO, R2OC/Winners, IndyRAGE 5th Alliance, WMRI QF
2016: IotaBot - MWR/16th place/QF, R2OC/7th Alliance Captain/QF, Boiler Bot Battle/6th place/Finalist
Unread 12-02-2016, 11:06
Chris is me's Avatar
AKA: Pinecone
This isn't a change. This is how the rules have been written since the beginning - the only "change" is the addition of a picture to better explain the rule. The rules have been like this every year we've had openings in bumpers, going all the way back to at least 2009.
