Go to Post If full body suits can be made to fit properly, why do we have so many robots with saggy bumper covers? - GaryVoshol [more]
Unread 07-02-2016, 13:52
galsasson galsasson is offline
FRC #5635
galsasson is an unknown quantity at this point
Problem with the dashboard
Hey guys! I am having troubles with the java dashboard. When I open the dashboard its crushing. I don't know what is the problem, but I think it's something with the configuratin. Does anyone knows where is the location of the dashboard file? Or how can I fix that?
Unread 07-02-2016, 19:09
minutebot minutebot is offline
Programming Captain
FRC #4536 (The Minutebots)
minutebot is a glorious beacon of lightminutebot is a glorious beacon of lightminutebot is a glorious beacon of lightminutebot is a glorious beacon of lightminutebot is a glorious beacon of light
Re: Problem with the dashboard
I remember to fix the Smart Dashboard I just reinstalled everything.
You can find the executable jar file here:
C:\Users\USER\wpilib\tools\SmartDashboard.jar
If it's a problem with the configuration file and it doesn't have the right file path you can edit it here, so it runs on start up.
C:\Users\Public\Documents\FRC\FRC DS Data Storage
and edit the command line line so it uses the SmartDashboard.jar filepath above on startup.
Unread 08-02-2016, 09:36
FRC #5635
It didn't help. The java dashboard is still crushing, unlike the default dashboard that works just fine.
Unread 09-02-2016, 16:08
Programming Captain
Yea ... I had that problem originally too. The way I ended up fixing it was reinstalling Java which made eclipse break but I got smartdashboard then I reinstalled Eclipse and everything worked out.
You may not find a more elegant solution, so I'd advise reinstalling so you can get back to work during build season ASAP.
Good luck!
Unread 09-02-2016, 16:09
Programming Captain
You are not alone too, here's the forum I started earlier in build season. I really just ended up reinstalling.
http://www.chiefdelphi.com/forums/sh...d.php?t=142281
Unread 10-02-2016, 09:56
FRC #5635
Thanks to everyone. I found the configuration file and I deleted it, and now the java SmartDashboard is working.
