Go to Post What, there is life outside of CD? - JB987 [more]
Unread 07-02-2016, 15:57
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: Bumper Rules on a U Bot Chassis
Originally Posted by ICE_Bear View Post
That was labeled "NOT OKAY" because the corner wasn't covered, not because it was less than an 8" piece of the side.
Since it's our chassis piece that's only 4.5 inches long, wouldn't each individual piece be a side?
Don't rely on pictures, READ the rules. If you just look at pictures you'll never get the whole story.
Earlier you referenced r19. Read r19. Then re-read r19 just to be sure. I'm on my 7th time through the full manual plus all the other times I have check little items in between. If you read it you'll get your answer and notice every side that is less than 8 inches must be fully covered. You'll also see that you need a minimum of 8 inches covered from each corner.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
