Go to Post Why is it considered shameful to do the smart thing? As the saying goes, "I don't make the rules, I just live by them." - Chris Hibner [more]
Unread 04-02-2016, 22:23
tjustic3 tjustic3 is offline
FRC #4576
tjustic3 is an unknown quantity at this point
pic: 4576 RNR CAD
Unread 04-02-2016, 22:24
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: pic: 4576 RNR CAD
Is the checkered black/white stuff carbon fiber?
Are the shooter and climber integrated as a single unit?
Unread 05-02-2016, 01:30
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
Looks pretty sweet. How do you plan to store enough air at high enough pressure to scale the tower with that honkin' cylinder?
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
Unread 05-02-2016, 05:29
FRC #4576
Yes that is correct on the carbon fiber. And yes the shooter and climber are integrated. When the shooter goes straight up when on platform it already got us half way up to the rung so we decided to add a 20" piston and the hooks. The piston closes and will lift the bumpers above low goal
Unread 05-02-2016, 05:32
FRC #4576
We have done the math and we can put 5 black clippard accumulator tanks at 100psi and we will be perfectly fine to run the piston both in and out without needing any air. We also have an air compressor filling the accumulators on the bot.
Unread 06-02-2016, 21:11
I just checked your math at 120psi, and it looks like you're good for exactly one pop- make sure you don't miss the bar! At that point, is there even a reason to use an compressor, though? You won't rebuild air nearly fast enough to be able to get enough pressure for a second actuation, and you can drop some weight if you don't have it on-board.
Unread 07-02-2016, 07:08
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
You also can run the extension and contraction ports of the cylinder at different pressures. You probably only need any substantial force in one direction.
Unread 07-02-2016, 11:33
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Have you considered extending a part of your shooting arm outside the frame perimeter to use as a manipulator? You could start the shooter in a vertical position to remain inside the frame perimeter during auton. I feel like an extension with a hook at the end would have a bunch of capabilities: opening Sally Port, lowering the Cheval the Frise, pulling the drawbridge down etc. What kind of gear ratio are you running to lift the arm? It looks like 2 cims in some pretty stacked versa planetaries.
Bison Robotics President
35 new FRC volunteers from Bison Robotics
The GreenHorns Project Lead:
Reveal Video
White Paper
Unread 07-02-2016, 17:01
mastachyra's Avatar
mastachyra mastachyra is offline
FRC #2781 (RoboPride)
mastachyra is just really nicemastachyra is just really nicemastachyra is just really nicemastachyra is just really nice
I'm not quite understanding how the hook rotate up? It looks like the cylinder just pushes the end out and the hooks don't have anything to pivot on...
2014: EtaBot - MWR/30th place/no PO
2015: ThetaBot - MWR/30th place/no PO, R2OC/Winners, IndyRAGE 5th Alliance, WMRI QF
2016: IotaBot - MWR/16th place/QF, R2OC/7th Alliance Captain/QF, Boiler Bot Battle/6th place/Finalist
Unread 08-02-2016, 08:41
FRC #4576
It is a 40 to 1 with a cim. We plan on running the arm to the back of the bot to use as a manipulator on some of the defenses.
Unread 08-02-2016, 08:45
FRC #4576
So the hooks will have a cable on the very front side (there is a small hole in the cad model) but on full extension of the cylinder will cause the hook to flip out because the cable will be just long enough to cause the book to spin on its attachment bolt.
