Go to Post People are human, refs are human. The refs did the best they could do at the time. - Andy Baker [more]
Unread 25-01-2016, 12:13
amstrudy amstrudy is offline
AKA: Anja Sheppard
FRC #0900 (Zebracorns)
amstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to behold
Can a RoboRIO be imaged with Labview and Java?
I was just wondering if the RoboRIO could be imaged with both Labview and Java because whenever I re-image it, it seems like you can only do one or the other.
Thanks!
Unread 25-01-2016, 12:49
Joey1939's Avatar
Joey1939 Joey1939 is offline
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
Re: Can a RoboRIO be imaged with Labview and Java?
The old cRIO had to be specially imaged for each language, but the roboRIO has just one universal image. As I understand it you can just deploy code from either LabView or Java or C++ and it will run the last code deployed.
Unread 25-01-2016, 13:04
FlamingSpork FlamingSpork is offline
Eating Utensil
FRC #3003 (Tan[X])
Rookie Year: 2015
FlamingSpork is just really niceFlamingSpork is just really niceFlamingSpork is just really niceFlamingSpork is just really niceFlamingSpork is just really nice
You will have to install Java on the RoboRIO if you want to run Java code.
http://wpilib.screenstepslive.com/s/...ller-java-only
I know that if you install Java you can still run C++ code, and I haven't tested with LabView.
Unread 25-01-2016, 15:28
LabVIEW runtime, vision libs, and C runtime is on the default image.
Greg McKaskle
Unread 07-02-2016, 19:07
HolyHacker335 HolyHacker335 is offline
FRC #4945 (Titanium Wrecks)
Rookie Year: 2015
HolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud of
Greg McKaskle
But, if Java image is installed on roboRIO, will that overwrite the LabVIEW image? Or will they coexist? The main question: Can LabVIEW be used on a roboRIO that has the default image? Thanks.
- Dave
Unread 07-02-2016, 19:12
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is offline
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
nickbrickmaster is an unknown quantity at this point
As others have said, it's not language specific. The roboRIO runs a more versatile OS than the cRIO did, and so can run any type of compiled code, provided it knows how. It's a bit like asking "Since I have LabVIEW installed, can I still run Eclipse?".
For Java, you must have the JRE installed, but LabVIEW and C++ can be run natively/with the provided image.
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 07-02-2016, 19:20
They will coexist.
Yes. By default, LV can be used and the runtime engine is running waiting for VIs to be loaded.
I think that Java would also be installed if the licensing issues could have been worked out.
Greg McKaskle
Unread 07-02-2016, 21:20
jds2001 jds2001 is offline
AKA: Jon Stanley
FRC #4263 (CyberDrgaon)
jds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud of
They will coexist.
<rant>
That will never be the case since Oracle is an evil company that doesn't have the best interests of their customers in mind. If they could have fully reversed the work that Sun did on opening up Java, I think they would have. They effectively killed any open source Solaris efforts, thereby rendering Solaris totally irrelevant, and leading many of the lead engineers to go work for someone to continue to innovate on the existing quasi-open (the CDDL is incompatible with the GPL, so no Solaris code can be integrated into, say, the Linux kernel) code base, but without any real resources to do so.
</rant>
Yeah, not having to download Java separately would be awesome! In view of the rant above, however, it's not going to happen unless an alternative Java implementation is used (OpenJDK anyone?) or NI negotiates some license with Oracle, likely for an absurd amount of money.
- Official Scorer
Disclaimer: I volunteer for FIRST as a referee. All opinions are my own, and do not reflect those of FIRST.
