Go to Post If winners never quit, and quitters never win, does it make sense to quit while you're ahead? - Billfred [more]
Unread 07-02-2016, 08:58
rcdturtle rcdturtle is offline
rcdturtle
AKA: Dick DuCharme
FRC #3534 (House of Cards)
rcdturtle is an unknown quantity at this point
How do you set up the Talon SRX in position mode using the CTR absolute encoder
We are trying to use a Talon SRX unit to control the angle of our pickup - shooter system. We have a VEX gearbox driving a chain gear that will have a range of motion of about 180 degrees. The encoder is mounted after the last stage so it should report the angle of the drive gear directly. While in manual mode, we are trying to move the gear in 0.5 degree steps (about 10 native units). When we enable the robot, the gear rotates part of a revolution and stops even though we have set the encoder position to zero and issued a talon.set(0) command in RobotMap. Is there someway to know where the encoder thinks the zero postion is. We are dealing with very small numbers because the set() command units are in rotations for position control. Should we be moving the encoder back a stage so the range of motion becomes 2.5 revolutions? If we do that, will the system still know where zero is? Is there an overall set up procedure for using the Talon SRX position mode with the CTR magnetic absolute encoder?
Thanks in advance for your help
Team 3534
Unread 07-02-2016, 09:04
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Re: How do you set up the Talon SRX in position mode using the CTR absolute encoder
Have you looked at this yet? Starts on page 49.
http://www.ctr-electronics.com/Talon...e%20Manual.pdf
Mike Copioli
CTRE Hardware Engineer
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 07-02-2016, 19:26
rcdturtle
AKA: Dick DuCharme
Yes I have. I have looked at most of the software manual. I did pick up an example at Git Hub that shows code that reads the least significant 12 bits, sets that as the initial position and uses the relative sensor from there. If I drive to zero from there, we could establish that as the zero position for the mechanism. Does that sound right?
Do you think using very small commanded position changes will be a problem?
