Go to Post I'm working, don't consume my oxygen. - DonRotolo [more]
Unread 07-02-2016, 21:34
snoman's Avatar
snoman snoman is offline
FRC #3275 (Accelerators 3134 & Regulators 3275)
snoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to behold
Surgical tubing
We were using Surgical tubing for our intake it is very grippy when new but as it gets dirty it looses grip. What is the best way to clean this stuff?
Coach of the Cass Lake Bena Regulators 3275 (Boys)and mentor Accelerators 3134(Girls)
https://www.facebook.com/accerleratorsandregulators/
https://www.youtube.com/channel/UCQU...Cr8I4wezAbMefA
Unread 07-02-2016, 21:40
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Re: Surgical tubing
On our polyurethane rollers last year we used germ-x and a cloth to clean it off. Rubbing alcohol is really what we were after but the jelly-like consistency made it convenient.
Potentially acetone (nail polish remover) might work, or it won't and instead might eat your intake. Try with caution.
Unread 07-02-2016, 21:42
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Surgical tubing
We used rubbing alcohol to clean and re-gripify our colsons last year. The same technique could work for surgical tubing.
Unread 07-02-2016, 22:33
TCMJ1816's Avatar
TCMJ1816 TCMJ1816 is offline
Peter
AKA: Peter Hartnett
FRC #1816 ("The Green Machine" (Alumnus))
TCMJ1816 will become famous soon enough
Re: Surgical tubing
In 2014 we used rubbing alcohol to clean our intake rollers too. We found that wet wipes were very easy to transport and apply. We just kept a box of them on the robot cart and it made the process simple.
To get what you've never gotten, you must do what you've never done.
Unread 07-02-2016, 23:35
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Surgical tubing
While I haven't done this in the past, I agree with the suggestion of alcohol; it should dissolve or colloid the same stuff that will stick to the rubber. If you're going to do some experimentation, add baby wipes to the list of things to test. They're alcohol based, very convenient, and easy to source in a pinch.
