Go to Post I could say that the decline in the population of pirates is responsible for global warming, the statistics correlate, but its obvious there's no causation there. - Racer26 [more]
Unread 07-02-2016, 22:39
ttakashima's Avatar
ttakashima ttakashima is offline
T^2
AKA: Travis
FRC #2504 (The Crusaders)
ttakashima has a spectacular aura aboutttakashima has a spectacular aura about
New Machine Shop
Hello CD Community
I am looking for assistance in choosing the best products to stock team 4270s new machine shop.
What we have:
JET JTM 1050EVS Manual Mill with 3 axis DRO
JET JTM 1050 with ACU-RITE 3 axis CNC
JET GHB 1340A Lathe - No DRO
2x JET Band Saw
Floor Mount JET JDP-20EVS Drill Press
What we are purchasing:
1 - Horizontal bandsaw, miter saw with bi-metal blade or abrasive chop saw
1 - belt/disc sander combo - probably JET with a 6in. belt
1 - Miller TIG welder and welding table
1 - Air Compressor ~40-60 gal capacity
1 - Bench Top Drill Press
2 - Shop Vacs
assorted power tools - drills, circular saws
MT3 and R8 Collet sets, R8 End Mill holders
assorted hand tools - Files, rubber mallets, socket sets etc.
I am looking for information for the list below:
1. KURT or Kurt Type work holding - I assume KURT is the go to brand for work holding.
2. Edge finders, digital preferred
3. End Mills and other cutting tools for the milling machines and lathe - Where do you buy your bits from? We are in Hawaii so Online sources are preferred.
4. Measuring tools, Calipers - digital, micrometers etc, I prefer Mituyo. Are there any other "good" brands?
Future Plans:
48x48 CNC Router
2 Bench top milling machines
2 Bench Top lathes
If I have missed anything important, please let me know. If you have any suggestions, please PM me or post here! We want to get this shop fully up and running by August.
Thank you!
T.Takashima
Team 2504/4270
I am used to running a limited resource shop so we usually buy cheap tooling etc.
Unread 07-02-2016, 22:44
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is offline
AKA: Clint Brawley
FRC #0364 (Fusion)
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
Re: New Machine Shop
I highly recommend a Velox CNC router, we bought one of these with a HSD 3HP spindel last year and we love it.
http://www.veloxcncrouters.com/#!vr-5050-4-x-4/c23m8
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
Unread 07-02-2016, 22:47
ttakashima's Avatar
T^2
AKA: Travis
That CNC router looks good! We will keep that in mind.
Travis Takashima
Team Leader: Team 4270 - 2016-beyond
Mentor and Team Leader: Team 2504 - 2009-2016
Team 2504 Alum 09'
Attending
-FIRST Hawaii Regional
-FIRST San Francisco Regional
Unread 07-02-2016, 22:54
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
+1. Our 2016 season would not be possible without it.
-Mike
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 07-02-2016, 23:19
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
What is the MT3 collet set for? It it's for the benchtop lathes I recommend moving to a 5c collet chuck instead of the MT3 spindle, as 5c collets allow for sticking stock out the back of the lathe.
I'm not sure you need R8 endmill holders either, as the Bridgeport-style mill you're looking at isn't going to be able to take more than a collet's load anyway. However, a pneumatic toolchager is fantastic for shorter students or just for convenience. It makes using the mill faster than walking over to the drill press.
You'll want vise and table-mount stops for your mill too for milling identical parts.
I generally look for deals on Ebay for non-precision stuff like clamps and stops.
If you buy benchtop mills, make sure they are not round-column. Dovetail column is practically a must due to numerous problems with moving round-columns up and down.
I would skip the horizontal bandsaw if you are already getting bandsaws and a miter saw. The latter two cover all your bases. Miter saws are easier to set up imo as well.
As far as edge finder I use manual, as they are cheap and repeatable. Electronics, while more expensive to be as good, are easier to use.
EDIT: make sure you do get a good indicator though for squaring up your spindle and table and centering holes.
End mills from closing machine shops and the like are my go-to (retired machinists also have good stock) but I highly recommend buying a carbide insert face mill for really nice finishes.
We have a Brown and Sharpe 6" for normal stuff and a 12" Mitutoyo for long stuff. I like both brands, and I think anything will work as long as it's reputable. Used Mitutoyos are really cheap on Ebay, but Brown and Sharpe are more expensive even used. Depending on the precision you're looking for used might be ok.
Dial calipers are easier to get a good measurement out of than digitals for me, as I can see the needle move to the "true" measurement.
I'm not sure you even need micrometers, as they are difficult to read and are usually overkill for FRC. However, a digital 0-1" Mitutoyo is only $40 used, and reads dead-on for shaft diameters.
A quiet air compressor lets people talk while working. I had to work with a really loud one for a couple years, and switching to a quiet one was an immense change.
Unread 07-02-2016, 23:32
snoman's Avatar
snoman snoman is offline
FRC #3275 (Accelerators 3134 & Regulators 3275)
snoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to behold
We just got one of these
http://www.cncplasmacutterinc.com/
Plasma router combo mills aluminum well
Coach of the Cass Lake Bena Regulators 3275 (Boys)and mentor Accelerators 3134(Girls)
https://www.facebook.com/accerleratorsandregulators/
https://www.youtube.com/channel/UCQU...Cr8I4wezAbMefA
Unread 07-02-2016, 23:50
ttakashima's Avatar
T^2
AKA: Travis
Thanks for the Reply asid61!
1.Ill look at the 5C collet chuck.
2. The R8 End Mill Holders are for quicker tool changes with tools of the same shank dia. although a collet + power draw bar would be just as quick. Maybe we can save some money here!
3. We are looking at 1 or 2 KURT 690s for the CNC and 1 for the Manual with 5/8 clamp sets for each.
4. I thought about purchasing boring heads but with the CNC I didn't think one would be necessary.
5. Good idea on the dove tail over round column bench top mills, ill look into that once we know what our future funding is going to look like.
6. The horizontal bandsaw is an option due to being safer to operate. We will probably buy an abrasive cutoff saw first though.
7. A carbide insert face mill would be a great idea!
8. Thats 2 for Mitutoyo! Ill look into purchasing Brown and Sharpe calipers too.
9. Yeah, we currently work with a rather loud compressor. This one would be located in a side room out of the way. A quieter compressor is still something ill look for.
Thanks for the advice!
Travis Takashima
Team 2504 Alum 09'
Attending
Unread 07-02-2016, 23:52
ttakashima's Avatar
T^2
AKA: Travis
@snoman
Would you be willing to share the details on cost/table size that you purchased?
Travis Takashima
Team 2504 Alum 09'
Attending
Unread 07-02-2016, 23:55
Tmeziere's Avatar
Tmeziere Tmeziere is offline
AKA: Tim
FRC #3021 (The Agency)
Team Role: Driver
Tmeziere is an unknown quantity at this point
My dad owns a cnc machine shop and he always buys end mills, vises and step jaws from MSC Industrial Supply.
Vices: http://www.mscdirect.com/product/details/09215112
Step jaws: http://www.edgetechnologyproducts.co...p-single-side/
For end mills I would recommend 1/4, 3/8, 1/2, all 3/32 all three flute carbide:
http://www.mscdirect.com/browse/Mill...navid=12106227
These ones work great: http://www.edgetechnologyproducts.co...p-single-side/
-Tim
Unread 07-02-2016, 23:58
frcguy's Avatar
frcguy frcguy is offline
#GearsAllDay
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Agreed. A horizontal bandsaw is nice, but it takes up a lot of space and takes a fair bit longer to set up. We got this compound miter saw and a higher-end non ferrous metal blade and it works great. Super easy to cut whatever angle you need very quick.
2017: Team 5940 (Silicon Valley Regional/San Francisco Regional)
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 08-02-2016, 00:01
ttakashima's Avatar
T^2
AKA: Travis
Those D688s are about $200 cheaper than the new 690, we may purchase these instead. Thanks for the info!
Travis Takashima
Team 2504 Alum 09'
Attending
Unread 08-02-2016, 00:35
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
I second all of this.
If your looking into bench top CNC mills look at the Nomad 883 by Carbide 3D, for the price its the best I've seen.
With edge finders I don't see the point in digital, just something else to run out of battery. The standard wigglers are great, Starrett is a reputable maker of those.
For dial calipers go Brown and Sharpe (what I use), they're the best. Starrett dial calipers aren't what they use to be. For digital I like the Mitutoyos.
For a quite compressor I think screw compressors are the way to go. 192 has a Kaeser.
Unread 08-02-2016, 09:50
Steven Smith Steven Smith is offline
FRC #3005 (RoboChargers)
Steven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond repute
One of the Youtube channels I frequent did a walk-around of a Kaeser screw compressor just a few days ago. I've got my eye on one as well.
https://www.youtube.com/watch?v=DDs5dr7whpM
2013 - 2017 - Mentor - Robochargers 3005
2014 - 2017 - Mentor - FLL 5817 / 7913
2013 - Day I Die - Robot Fanatic
Unread 08-02-2016, 10:17
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We have two of this compressor.First one was installed about 3 and a half years ago, and it's been great since. It's able to keep up with two CNC mills with blow guns and air-powered hand tool usage without a problem.
Unread 08-02-2016, 11:08
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
A rotary screw compressor is not the answer for that equipment mix. Save $5k and get a good quality 2 stage reciprocating compressor that runs at 800 rpm. The 800 rpm ones are significantly quieter than the 1750 or 3450 rpm ones.
2001-2004: Team 100
2006-Present: Team 254
