Go to Post Don't worry about where you will be. Just consider youself lucky for being where you have been. - sanddrag [more]
Unread 07-02-2016, 20:09
KG2V KG2V is offline
FRC #1155
KG2V is an unknown quantity at this point
Out of Spec CIM motor
Hey Guys and Gals
I was mentoring the kids on one of my teams (1155 and 2265) and found an out of spec CIM motor, in that one of the 10/32 mounting holes was way more than the specified 1 deg out of alignment from the 90 deg mark (by more than 1/2 the hole diameter - I could do the math, not important)
Not sure what the team wants to do (we have spares, so...) but wanted to give a heads up in case anyone has not checked their motors
Unread 08-02-2016, 00:05
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Out of Spec CIM motor
More than 1/2 the hole diameter? That's massive. We definitely would have noticed by now. If it came in the KoP, it's too late to submit it as a problem. If you bought it in the past few months, you can probably get a replacement from the vendor.
Unread 08-02-2016, 00:37
TheHolyHades1 TheHolyHades1 is offline
TheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the rough
Could you post a picture please? I'm curious to see what it would look like. Additionally, you may wish to contact the vendor to see if they can do anything. FRC vendors tend to have some of the best customer service I've dealt with.
Unread 08-02-2016, 10:05
Breadbocks Breadbocks is offline
FRC #1002
Breadbocks is on a distinguished road
My team has had a CIM which is significantly larger than standard sitting around the shop for quite a while, I'll see if I can get pictures of it later today. I remember it being a larger diameter, but nothing came up when i googled the part number.
Unread 08-02-2016, 10:12
pfreivald's Avatar
AKA: Patrick Freivald
The extra-large CIMs came in the kit years and years ago, but haven't been legal for a long time. (We have, I think, four.)
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 08-02-2016, 10:21
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
If I recall correctly, the unusually large CIM was the "minibike motor", last used in the 2006 KOP.
Unread 08-02-2016, 10:42
FRC #1002
That's actually really interesting to know, thanks. I always figured it just got sent in place of a proper CIM on year by mistake.
