Go to Post Stand up and cheer for yourselves and others. That is FIRST, don't change it. - Steve W [more]
Unread 08-02-2016, 08:53
pfreivald's Avatar
AKA: Patrick Freivald
Re: Chain or gear drive?
Originally Posted by Bruceb View Post
we started using belt drive a few years ago and we will NEVER go back to chain.
with the correct spacing you never need a tensioner. Set it and forget it.
I'm curious what you're gearing your belt-drive bot to, and what kind of belts/pulleys. We just switched *to* chain after several years of belts, because in very-high-torque pushing matches our 15mm HTD belts would jump even with laser-cut center-to-center mounting plates (and then even with delrin tensioners).
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
