Go to Post Nothing worse than an intolerant field :D - JB987 [more]
Unread 08-02-2016, 08:56
Re: Navx Mxp no longer working
Modifying the project framework (e.g. by adding an output to Begin) is usually a bad idea. Using the Refnum Set/Get functions is preferred.
The -44007 error you were getting suggests that you had spelled the name of your NavX reference differently in the two places.
Unread 08-02-2016, 14:45
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
It's too bad about the USB not working. We used that to get the navX into a good location on the robot, where we could not fit the roboRIO.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
