Go to Post you know you are addicted to first when u crave sprockets for breakfast! - Jones571 [more]
Unread 08-02-2016, 08:44
BlacksmithEJ BlacksmithEJ is offline
FRC #0806 (Brooklyn Blacksmiths)
BlacksmithEJ is an unknown quantity at this point
Re: best way to temp mount battery
Gaffers tape, lots and lots of gaffers tape
Unread 08-02-2016, 09:16
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Originally Posted by Anupam Goli View Post
Large zipties, one of the AndyMark battery mounting kits, or a tie-down kit will work for temporary mounting purposes.
But make sure temporary doesn't turn into permanent. Like Chris said, start designing a permanent solution to take use of existing robot geometry. You don't want to go out on the field and have your season ruined by a loose battery
Why wouldn't you trust the AM battery mount kit as a permanent solution?
Hi!
Unread 08-02-2016, 11:02
hardcopi hardcopi is offline
AKA: Rich Lester
FRC #2959 (The Robotarians)
hardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud of
We ordered ours without Death...
How much you have to do to secure it depends on the frame you are using. Also what do you mean by a "few runs". If you are running around on the flat floor, some zip ties would probably be fine (we have some really thick ones), but if you are going over/through obstacles you might need more. Also, do you have anything really solid to attach to, etc.
Unread 08-02-2016, 11:09
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
If you have a kit chassis you have scrap pieces from it. Those scrap pieces happen to fit perfectly on a battery. So, cut 1 of them in half and bolt it to your frame. Get a Velcro strap and bam Permanent Battery holder in 5 minutes.
I do not see a point to a temporary battery holder.
Unread 08-02-2016, 11:41
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
That is a very expensive battery mount.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 08-02-2016, 14:25
Chak Chak is online now
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Originally Posted by matthewdenny View Post
Remember that the battery is a 8lb box of acid, death and lead. When in doubt mount it more solidly then you think you need.
More like 14lbs. So, it's even worse than you thought!
Unread 08-02-2016, 14:37
PowerfulKitty PowerfulKitty is offline
Drive Coach
AKA: Alex Dalziel
FRC #5576 (Team Terminator)
Team Role: Driver
PowerfulKitty will become famous soon enough
We've just been running with it held down by a small aluminum base and an old leather belt.
