Go to Post Robot gets bored during practice, wanted to listen to some podcasts. - Tom Bottiglieri [more]
View Poll Results: Which defense would you choose? Please select one from each category (A,B,C,D).
(A) Portcullis 96 54.55%
(A) Cheval de Frise 73 41.48%
(B) Moat 95 53.98%
(B) Ramparts 78 44.32%
(C) Sally Port 75 42.61%
(C) Drawbridge 87 49.43%
(D) Rock Wall 111 63.07%
(D) Rough Terrain 62 35.23%
Multiple Choice Poll. Voters: 176. You may not vote on this poll
Unread 08-02-2016, 09:09
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Pick Your Defense
If you had to choose one defense for each section, and stick with that defense throughout the qualifications, which 4 would you select and why?
Hi!
Unread 08-02-2016, 09:13
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
Re: Pick Your Defense
Category A:
Portcullis: Not many teams will be able to be successful at this defense.
Category B:
Moat: Its deceptively hard, it will be the most likely defense so see Tortugas this season.
Category C:
Sally Port: Its going to be a little harder to score on this one with alliance help than the Drawbridge.
Category D:
Rock Wall: Rough Terrain is very easy to cross.
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 08-02-2016, 09:31
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Barring any actual knowledge of opponent abilities, this is how I'd go:
A: Cheval de Frise - doesn't block vision as much as the drawbridge, requires precision driving
B: Ramparts - likely to flip a robot that attempts a "Dukes of Hazzard"-style crossing
C: Sally Port - harder to open from outside as it requires compound movement, blocks vision less
D: Rock Wall - I remember how few robots could clear the barrier back in Rebound Rumble.
Unread 08-02-2016, 09:43
Zebra_Fact_Man's Avatar
Zebra_Fact_Man Zebra_Fact_Man is offline
]\/[ Go Blue!
AKA: Solomon
FRC #1076 (Pi Hi Samurai)
Zebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant future
See, I'm going the exact opposite direction. I'm trying to pick everything that blocks everyone's view as MUCH as possible. We plan for our robot to operate as autonomously as possible during teleop navigating the field, so we won't much mind having difficultly seeing if everyone else does too.
My Journey in FIRST:
Mentor/Coach/Engineer
2014-2017: Team 1076 - Pi Hi Samurai
____ 2014: Team 5220 - The Rockets
2009-2014: Team 313 - The Bionic Union/Bionic Zebras
Student
2006-2009: Team 313 - The Bionic Union
Unread 08-02-2016, 09:46
BoilerMentor BoilerMentor is offline
FRC #1747
BoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond repute
I voted portcullis, rock wall, draw bridge, moat...
However, something we realized when considering this very issue is that while the rock wall and the moat are likely the more difficult driving (Type B and D) defenses, the rough terrain and the ramparts might have a more notable effect during auto, because they don't provide consistent frontal area across their width and might induce an angular misdirection.
2006-2008 FIRST Team 1741 Red Alert-Founding Student
2008-2011 FIRST Team 1747 Harrison Boiler Robotics-College Mentor
2012 FIRST Team 4272 Maverick Boiler Robotics-Founding College Mentor
2013-Present FIRST Team 1747 Harrison Boiler Robotics-Engineering Mentor
2015-Present Ri3D Team Indiana - Mechanical and Fabrication
Unread 08-02-2016, 09:58
Drakxii Drakxii is offline
FRC #4131 (Iron Patriots)
Drakxii is just really niceDrakxii is just really niceDrakxii is just really niceDrakxii is just really niceDrakxii is just really nice
IMO FRC is about speed so...
A - Cheval de Frise - It simply can't be done fast, as it will require precision driving since the arms need to move down as the bot moves up the ramp. Portcullis on the other hand can be quick defeated with fast well engineered arms.
B - Ramparts - More likely to throw fast bots off center then the moat will. Though if I thought the other team might high center on the moat I would go with that.
C - Sally Port - Harder hold open without getting in the way then the drawbridge.
D - Rough Terrain - Again will throw bots off center, also might high center teams. Rock wall will be easier to beat then people think with the ramp that leads up to the platform.
Michael D.
Favorite game: Aerial Assist
Least Favorite: Recycle Rush
Pantherbots Mentor - #2582 Lufkin, TX
* Lone Star Regional 2016, 2015 - 3rd place (Semifinals), 2014 - Quarterfinals, 2013 - Quarterfinals (Judges Award)
Iron Patriots Mentor - #4131 Renton, WA
PNW Ranking: 2016 - 18
* Auburn Mountain View District Event 2016 - Semifinals (EE Award)
* Auburn District Event 2016 - Finalists (ID Award)
* PNW Champs 2016 - Quarterfinals
* World Champs 2016 - Carson
Unread 08-02-2016, 10:04
ASmith1675's Avatar
ASmith1675 ASmith1675 is offline
Mechanical/Electrical/Scouting
AKA: Adam Smith
ASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to behold
I had this exact thought. At the regional level of competition, the rock wall and moat might be the ideal selections, but as the level of competition increases and scoring in autonomous becomes more likely and more critical, the random nature of both the rough terrain and ramparts might be more advantageous.
I'm very excited about the strategic possibilities that this game sets up. Should make for an interesting meta-game as the competitions progress.
Unread 08-02-2016, 10:15
Logan Byers Logan Byers is offline
Roaming Mentor & Referee
no team (Team Indiana)
Logan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud of
A: Cheval de Frise - from my perspective on Team Indiana for Ri3D, we had to take more time manipulating the Shovel the Fries in order to traverse. The Portcullis wasn't as tough to manipulate and drive under.
B: Ramparts - While the moat can maybe catch a couple of wheel bases, the Ramparts will ultimately prove to be the most upsetting defense. You don't come out straight after driving through the Ramparts.
C: Sally Port - Both of these defenses can be easily traversed with some teamwork. But, if we're just talking one robot, the Sally Port is more awkward to manipulate.
D: Rock Wall - 4.5" ground clearance vs. small increments (3" or <) rough terrain. Rock wall is the easy choice here.
Hgree56's Avatar
Hgree56 Hgree56 is offline
AKA: Hunter Greene
FRC #4272 (Maverick Boiler Robotics)
Hgree56 will become famous soon enough
My picks:
Portcullis: Most teams I know aren't planning on going for it
Ramparts: unless your drive train is designed to go over it, you aren't
Drawbridge: One of our mentors was on Ri3D Team Indiana and he said it was the hardest defense to cross
Rock Wall: like the ramparts, unless you're designed to go over it, you aren't
2016 Indiana Tipp. District Industrial Safety Award winner
2016 Indiana Perry M. District QF w/ (3487 & 4580)
2015 Indiana Purdue District Chairman's Award winner
2015 Indiana Indianapolis District QF w/ (5403 & 4008) and Industrial Safety award winner
2015 Indiana Indianapolis, Purdue, and State Champs Industrial Safety Award Winner
2014 Crossroad GP Award Winner
2014 Boilermaker SF w/ (337 & 4213)
Unread 08-02-2016, 10:21
Taylor's Avatar
AKA: @taylorstem
My choices were based on where gamesmanship meets gracious professionalism, and the murky waters* therein.
A: Cheese Fries are more time-consuming to defeat than the Pork cutlets. So CDF.
B: Teams are more likely to self-damage while performing Dukes Of Hazzard maneuvers, so Moat.
C: Sally Port is slightly less visually obtrusive, and I think requires more precision in teamwork to defeat.
D: Rock Wall for same reason as B.
To explain B and D - of course if a robot gets damaged executing some "hey y'all watch this" maneuvers, we'll send some of our pit crew over to help with repairs. This will also give our scout team and mechanical team some good info regarding robustness of robot designs, which could help us should we find ourselves in an alliance picking position.
*despite what you might think, this is not a direct confirmation of WATER GAME
Hi!
Unread 08-02-2016, 10:56
FRC #1747
It sounds like your pork cutlets are overcooked...
In all seriousness, I think type A will be the most variable one team to team. As of right now, we're struggling a bit with the portcullis, but Cheval de Frise takes only a few seconds more than the low bar. I believe our issues are mostly due to the the poor analog the version in the team field elements provides and that on a real field we probably wouldn't have any issues.
I really firmly believe the portcullis, is the maneuver requiring more coordination and could also serve as a robot trap if the door falls in an inconvenient spot.
Unread 08-02-2016, 11:27
TheSousaLife's Avatar
TheSousaLife TheSousaLife is offline
Team Role: Scout
Rookie Year: 2015
TheSousaLife is an unknown quantity at this point
I choose the Cheval, Rock Wall, and Ramparts. Mainly for the engineering difficulty required in crossing. However for placement. I think things like the Cheval and Ramparts will be placed more towards the middle and things such as the rock wall towards the outside. The reasoning is autonomous is harder on the side. So put more technical obstacles or ones that will upset autonomous should go more toward the center.
Unread 08-02-2016, 12:15
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Sweet. Rock wall to the outside make my plans for a low-goal autonomous much easier.
Unread 08-02-2016, 12:53
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I voted by basing it off of top teams in quals at any event: inhibit autonomous as much as possible by injecting as much chaos as possible into autonomous routines. The crossing is a given for the most part - but surely we can make the shot(s) afterwards slightly more difficult.
Seems like pretty straightforward picks from that perspective:
- Cheval-De-Frise injects pitch and semi-unpredictable traction slip into the autonomous routine, whereas the Portcullis is the same super-simple routine every time.
- Ramparts require 'average' robots to contend with two rotational acceleration components (pitch & roll) rather than the moat's one (pitch). Autonomous traversal of the moat is so simple with the drive train that 2-ball autonomous routines will fill the moat with opponents' tears.
- Draw Bridge requires more movement of the drive train, whereas the Sally Port can be solved via extensions and little drive train movement. The first ball is probably a given for either, but IMO the draw bridge inhibits the 2nd ball the most.
- Rock Wall creates a high-side for most robots that must be accounted for in software or mechanisms, whereas a straight autonomous path through the rough terrain can be experimented with an eventually planned into how the robot is set down onto the field.
GitHub
Unread 08-02-2016, 14:52
Tharioth Pillow's Avatar
Tharioth Pillow Tharioth Pillow is offline
Twenty-One Cappuccinos and a Cat.
AKA: Joey Jordan
FRC #4967 (That ONE Team)
Team Role: Communications
Rookie Year: 2015
Tharioth Pillow is on a distinguished road
Does anyone else call them the Chile Fries? It's sort of a team thing now.
