Go to Post Last I checked, this was a competition... just checked again, yup still has Competition in the name. - Andrew Schreiber [more]
Unread 08-02-2016, 11:19
lark95's Avatar
lark95 lark95 is offline
Red Ranger
AKA: Joe L.
FRC #3418 (RoboRiot)
Team Role: Driver
lark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of light
Video: RoboRiot Team 3418 Tank Tread Test
Here is a Video of some tests going over the defenses with our custom tank drive. Each side is powered by a custom 2 CIM bevel gearbox with a 2:1 ratio. The rest of the gearing is accomplished by a 9 tooth sprocket and 23 tooth gear on the back drive wheel. Final ratio is 5.11 to 1. It uses the same type of belt as the Andymark Rhino treads however we sourced them with a different tread type. The side plates are 1/4 inch 6061 aluminum. We weighted it down with a cinderblock and some big chunks of lead to around 150lbs. We have been really pounding this chassis going full speed into all the defenses both forwards and backwards. So far it is holding up great. The only thing we have broken is the cinderblock. We hit a few times so hard it cracked into 3 pieces.
https://www.youtube.com/watch?v=ImqJSSZPrCw
FRC Rebound Rumble | Ultimate Ascent | Aerial Assist | Recycle Rush | FIRST Stronghold | FIRST STEAMWORKS
FLL Senior Solutions | Nature's Fury | Trash Treck | Animal Allies
Unread 08-02-2016, 11:22
Toatekua's Avatar
Toatekua Toatekua is offline
Ducttape-O-Maniac and Gif Master
AKA: Jess
FRC #3418 (Robo Riot)
Toatekua is an unknown quantity at this point
Re: Video: RoboRiot Team 3418 Tank Tread Test
When did the cinderblock get cracked? I don't remember that?
