Go to Post Learn to respect the opinions of others, even if they are the complete opposite of yours. - Hallry [more]
Unread 08-02-2016, 11:30
Tzury-Orbit1690 Tzury-Orbit1690 is offline
FRC #1690 (Orbit)
Team Role: CAD
Rookie Year: 2015
Tzury-Orbit1690 is just really niceTzury-Orbit1690 is just really niceTzury-Orbit1690 is just really niceTzury-Orbit1690 is just really niceTzury-Orbit1690 is just really nice
How much air pressure should you fill the pneumatic wheels with?
My team is working with WCP 6" pneumatic wheels and we were wondering how much air pressure should we fill?
Right now we are working with about 25 PSI but we are not sure about what is the optimal air pressure for these kinds of wheels.
Unread 08-02-2016, 14:21
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: How much air pressure should you fill the pneumatic wheels with?
I would fill them until they are full. What full is will be completely dependent on your application. We are running our center wheels at 35 psi and our outer wheels at 25 psi right now. We might up that depending on how much weight we have to lug around after all our subsystems are mounted.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 08-02-2016, 14:34
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Fuller tires (up to the rated pressure of the tire) will give you better performance and durability on level ground. Lower tire pressure (though enough that the rims don't hard stop against an obstruction) will give you better grip for climbing over obstacles, at a cost of frame efficiency and shorter tread life. It seems best to use the highest pressure that reliably gets you over all the obstacles you intend to cross.
Unread 15-02-2016, 13:44
abross's Avatar
abross abross is offline
FRC #5113 (Combustible Lemons)
abross is on a distinguished road
As reference, when I go offroading, I air down my tires from around 28 psi to 13 psi. This number came from a lot of guess and check to see what pressure worked best for me.
Obviously, these 6" wheels (my team is also using these) are much smaller, so the difference in contact area when airing down will be drastically different, but I do have some neat reference pictures.
My team hasn't tested this yet as we are waiting to see how heavy the total robot will be. My suggestion, put your robot on the rock wall so the front wheels are on the edge of the wall, then start letting air out until the edge pushes into the wheel so you have contact on the vertical and horizontal face of the wall. This is obviously just an example and you can use this idea on any obstacle, but this is how we plan on testing ours.
2009-2010: Storm Robotics 2729 (Student)
2014-****: Combustible Lemons 5113 (Lead Mentor)
Unread 15-02-2016, 14:07
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
we got 25 psi on a 8 wd. We get good traction and they're hard enough so we don't hit the plastic rims when going duke of hazard mode on the rock wall
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
