Go to Post I don't mean to sound harsh, but I do not want you to get your hopes up. There are deadlines in FIRST. - RoboMom [more]
Unread 08-02-2016, 11:19
dmorewood's Avatar
dmorewood dmorewood is offline
Lead Designer / Coach
AKA: Drake Morewood
FRC #1218 (Vulcan)
Team Role: CAD
dmorewood is just really nicedmorewood is just really nicedmorewood is just really nicedmorewood is just really nicedmorewood is just really nice
9" Diameter Wheels
We had originally designed our drive chassis to be fit with the Andy pneumatic wheels. We're now looking at these wheels on a drive train compared to the defenses and thinking that they're rather small. We have 6 8" diameter wheels from earlier this wheel, but would prefer to find even bigger wheels. Our design constraints dictate that the biggest we can go as of now if 9.75" diameter with a 2 inch width. Does anyone know where to buy wheels between 8.5-9.75" in diameter and that have a 2" width? We need 12 if that's possible.
Unread 08-02-2016, 11:31
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
Re: 9" Diameter Wheels
First off, have you tested the wheels? I assure you that if you designed to use 8" wheels, you should try them out. Our team is able to get over the defenses with 6" wheels. Secondly, if you swap wheels, you'll need to modify your Gearbox so you can keep a reasonable speed, so keep that in mind.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 08-02-2016, 11:50
dmorewood's Avatar
AKA: Drake Morewood
FRC #1218 (Vulcan)
Team Role: CAD
Our wheels our enclosed within the chassis so we're pretty sure were going to hit the rock wall and stop with the Andymark wheels. The gearbox can be fixed rather painlessly if need be.
Unread 08-02-2016, 11:57
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
You could look into a system like Wildstang in 2012 to raise the front end and get the wheels on the defenses if space and weight allow.
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
Unread 08-02-2016, 11:59
dmorewood's Avatar
AKA: Drake Morewood
FRC #1218 (Vulcan)
Team Role: CAD
Unfortunately our sheet metal chassis is set in stone at this point. We also only have three inches of clearance currently between our bumpers and the floor.
Unread 08-02-2016, 12:13
Jarren Harkema's Avatar
Jarren Harkema Jarren Harkema is offline
Dancing Drive Coach
FRC #4967 (That ONE Team)
Jarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to all
Bumper or chassis? Read the bumper rules carefully, they must be within the bumper zone.
Unread 08-02-2016, 12:32
dmorewood's Avatar
AKA: Drake Morewood
FRC #1218 (Vulcan)
Team Role: CAD
Sorry I meant Chassis, the bumpers will be 4 inches above the floor. Thought's on doing something like 1114's 2012 chassis design?
Unread 08-02-2016, 12:56
jamesmcip jamesmcip is offline
It's fine, don't worry about it
AKA: James Cipolletti
FRC #4908 (Dragons)
Team Role: CAD
jamesmcip is a glorious beacon of lightjamesmcip is a glorious beacon of lightjamesmcip is a glorious beacon of lightjamesmcip is a glorious beacon of lightjamesmcip is a glorious beacon of lightjamesmcip is a glorious beacon of light
Our team has run into a similar issue, as the 8" wheels are surprisingly small. Once our chassis was done, we realized we couldn't get over the rock wall and moat, but by simply using flexible plastic "skid plates" on the front to reduce the angle of attack we were able to do everything as planned.
Unread 08-02-2016, 13:14
dmorewood's Avatar
AKA: Drake Morewood
FRC #1218 (Vulcan)
Team Role: CAD
Soooo like 1/8th lexan? And you can get over the rock wall with this?
Unread 08-02-2016, 13:19
page2067's Avatar
page2067 page2067 is offline
AKA: rick page
FRC #2067 (Apple Pi)
page2067 has a spectacular aura aboutpage2067 has a spectacular aura aboutpage2067 has a spectacular aura about
Mountain Board Systems has a 9" x 2" tire (9" is really about 8.5")
Unfortunately they have been wiped clean of their inventory it appears - and won't have them until end of February per the website.
But we used them in 2012 and they provide nice customer service, suggest giving a call to them.
Unread 08-02-2016, 13:32
FRC #4908 (Dragons)
Team Role: CAD
Yeah Lexan would work fine, we just used some random ABS I think and yes we could get over the rock wall with only 3" of clearance.
Unread 08-02-2016, 16:22
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Assuming you guys are comfortable making/modifying hubs, Harbor Freight has an option:
http://www.harborfreight.com/8-inch-...ire-47638.html
They are listed at 8", but are closer to 8.5" IIRC. There's a few Harbor Freight locations around Philadelphia (Sharon Hill, Norristown, Northeast Philly) if you want to inspect them in person.
Unread 08-02-2016, 17:43
Max Boord Max Boord is offline
FRC #0179 (The Children of The Swamp), FRC #1592 (Bionic Tigers)
Team Role: Tactician
Max Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant future
+1 for the the Harbor Freight tires. They have similar grip to colsons and are between 8.5 and 8.75 inches in diameter depending on inflation. They also have the + of only being 8 dollars each. For hubs we grinded out the center bearing housings and laser cut some plates with a hex in the middle that bolted on with the pre existing hole patern. They are quite heavy however, so they may or may not be an option.
Harbor freight also sells the same size wheel as a castor with a black wheel. It is not nearly as grippy as the one linked above.
1523 (2011-2014)
1065 (2014-2016)
3932 & 4592 (2016)
Unread 08-02-2016, 17:55
dmorewood's Avatar
AKA: Drake Morewood
FRC #1218 (Vulcan)
Team Role: CAD
These are great if their actually 8.5". The color is an added plus. Would we be able to use the vexpro hex hub kit? We already own and were planning on using these. What is the width of those wheels?
Unread 08-02-2016, 18:22
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Don't know the width off-hand.
The Vex hubs won't fit the wheel natively, but it could be adapted if you're careful to ensure it's centered.
