Go to Post Hey Don, if the [Woody Flowers] award doesn't impress the non-FIRST friends and family, just tell them you have your own "inter-web thread" - tell them you are like a Chuck Norris on the internet!!! - ebarker [more]
Unread 02-08-2016, 01:47 PM
tuskiomi tuskiomi is offline
None #2531
tuskiomi is an unknown quantity at this point
mdns won't work with new radio
SOLVED. Solution below
My team has been having this problem for the past few weeks now, and I cannot seem to find a solution.
We can control the robot and have code, but there is no support for mDNS.
Normally this wouldn't be an issue, but our Smart Dashboard is not behaving properly because of this. We just re-flashed the router yesterday, and there is no luck. We also cannot connect to 172.22.11.2
ping result:
SOLUTION: turn off IPV6 adresses
Unread 02-08-2016, 01:56 PM
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Team Role: Student
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
Re: mdns won't work with new radio
Make sure whatever firewall you have on your laptop is disabled.
Unread 02-08-2016, 02:10 PM
None #2531
disabled firewall, re-installed firmware & configuration. no luck.
Unread 02-08-2016, 02:15 PM
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Make sure you are using the correct Mdns name for the roborio in the smart dashboard.. It should be roborio-TEAM-frc.
Unread 02-08-2016, 02:26 PM
None #2531
should '.local' be added to the end?
Unread 02-08-2016, 02:38 PM
virtuald's Avatar
virtuald virtuald is online now
RobotPy Guy
AKA: Dustin Spicuzza
Yes, "roborio-XXX-frc.local". I've found that "roborio-XXX-frc.lan" works a bit more reliably for me.
Unread 02-08-2016, 02:46 PM
None #2531
That's how the Driver's station is setup. Do I have to set the IP for the Smart Dashboard separately?
Unread 02-08-2016, 03:07 PM
krieck's Avatar
krieck krieck is offline
AKA: Keith
FRC #2846 (Firebears)
krieck is an unknown quantity at this point
Microsoft Windows doesn't support mDNS by default. The National Instruments installer will add mDNS support. If you are running SmartDashboard on a PC that hasn't had the driver station installed, then this might be the problem.
The test for this problem is with the "ping" program run from your command line. If you can ping to the IP address but not to the mDNS address, then you're missing the mDNS software.
The solution is to install Bonjour Print Services from Apple. Really. Some of our students are incredulous that they need Apple software to talk to the robot, but yeah, they do.
Unread 02-08-2016, 03:10 PM
The nimdnsResponder is based on the Apple Bonjour implementation, by the way. So either installation will work.
Greg McKaskle
Unread 02-08-2016, 03:26 PM
None #2531
alright. I'll try installing when I get the PC again. The FIRST documentation says that and mDNS service is installed with the update suite. any insight on that?
Unread 02-08-2016, 03:37 PM
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
The Mdns name is roborio-TEAM-frc. You can confirm that by looking at the roborio name in its dashboard. The .local tells the web browser that is a local address. The .lan is appended unto the name by the radio. Sometime one works better than the other. I am not expert enough on what is really going on to have a good explanation why.
The smartdashboard target is set in the smartdashboard. I think under the files menu? I think it generally gets set automatically. Also network table was redone this year. I don't know if last years will work with the 2016 version. So if didn't completely uninstall last years stuff, that might be a problem as well.
If the driver station is finding the roborio, does that prove the Mdsn is working?
Unread 02-08-2016, 03:43 PM
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
The name of the service installed with the update suite is called "NI mDNS Responder Service". You can check if its in the services list and if its running. Its installed to "C:\Program Files (x86)\National Instruments\Shared\mDNS Responder\nimdnsResponder.exe"
We switched our roboRIO to a static IP and put the address we set it to into the hosts file to avoid mDNS issues.
Brian K
Team 1225 Robotics Mentor
Unread 02-08-2016, 03:44 PM
None #2531
does the Smart Dashboard still work with static IP?
Unread 02-08-2016, 06:25 PM
None #2531
posted ping results
Unread 02-10-2016, 11:48 AM
wesleyac's Avatar
wesleyac wesleyac is online now
AKA: Wesley Aptekar-Cassels
FRC #1678
wesleyac is a glorious beacon of lightwesleyac is a glorious beacon of lightwesleyac is a glorious beacon of lightwesleyac is a glorious beacon of lightwesleyac is a glorious beacon of light
When you disabled IPv6, was that on the radio, or on the rio?
We've had issues with mDNS in the past, so it would be nice to know if there's a simple solution.
Originally Posted by The programming team
Define "works."
