Go to Post Be watchful of the "man this is so cool we should do it in build" as I've embarrassingly fallen victim to it so many times before, with varying results. - Aren_Hill [more]
Unread 08-02-2016, 16:17
Alex Walsh Alex Walsh is offline
FRC #4122 (O-Bots)
Alex Walsh is an unknown quantity at this point
Exclamation Grip Bug Deploy
We have deployed the latest version of of GRIP (1.2.0) and we are having the error:
/usr/local/frc/JRE/bin/java null -jar '/home/lvuser/grip.jar' '/home/lvuser/project.grip'
/home/lvuser//grip: line 4: /usr/local/frc/JRE/bin/java: No such file or directory
I think the problem is that GRIP adds two "/" instead of one here /home/lvuser//grip, when I just entered /home/lvuser for the deploy directory.
If someone knows how to fix this error please let me know
Thank you
Unread 08-02-2016, 16:43
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
The issue appears to be that you haven't installed Java on the RoboRIO. Make sure you've done that before deploying GRIP.
Unread 08-02-2016, 16:53
FRC #4122 (O-Bots)
Re: Grip Bug Deploy
I already did that and then did a fresh install of it when I was getting this erroe, no dice.
Unread 08-02-2016, 17:24
WPILib Developer
FRC #0190
This error is that it can't find the Java installation, that's the path the Java installer puts it in. Are you sure that Java is on the RoboRIO?
Unread 08-02-2016, 17:58
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is offline
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
nickbrickmaster is an unknown quantity at this point
Re: Grip Bug Deploy
In the JRE args field, put a space instead of a blank.
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 08-02-2016, 23:00
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
Re: Grip Bug Deploy
Better yet, put:
-Xmx50m -XX:-OmitStackTraceInFastThrow -XX:+HeapDumpOnOutOfMemoryError
This is a bug in how GRIP treats old project files from before we added the JVM args option. The option was added because the above arguments can help with memory usage problems on the RIO.
GRIP (Graphically Represented Image Processing) - rapidly develop computer vision algorithms for FRC
