Go to Post It is NOT possible to fail within FIRST. It IS possible to fail within the competition (whatever your criteria for failure may be). - JVN [more]
Unread 08-02-2016, 16:32
Sparta3648's Avatar
Sparta3648 Sparta3648 is offline
Mentor of team 3648
FRC #3648 (Sparta Robotica)
Sparta3648 is an unknown quantity at this point
Linear Actuators
For an arm we intend to build we plan on using linear motor powered actuators. However the ones we need to use (which reside within game manual specifications) use motors outside the registered motor list found in the game manual. Would we be allowed to use these actuators and these motors or would we have to buy AndyMark actuators with approved motors?
Unread 08-02-2016, 16:38
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Linear Actuators
The only motors you are allowed to use are the ones listed in the game manual. So you cannot use motors not listed game manual.
Unread 08-02-2016, 17:00
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
True statement.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 08-02-2016, 17:20
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
As stated, only approved motors allowed. That does not, however, mean you need to use AndyMark actuators or nothing... You can always use the other ones, provided you swap out the motor for a legal one. Depending on the actuator, this may or may not be a straightforward exercise.
2016: Lake Superior WFFA
