Go to Post Canada has five regional events now. Canada. - Nick Lawrence [more]
Unread 08-02-2016, 18:50
JimmyBobJones JimmyBobJones is offline
FRC #6078
JimmyBobJones is an unknown quantity at this point
Code not deploying properly?
So using Ecplipse when I deploy the code it tells me it's all going well in the console. But the driver station stills shows no robot code. Do we have to reimage the rio? It worked before a couple days ago.
EDIT: Console output: http://pastebin.com/UqkW3PM1
Error Message in Driver Station: http://pastebin.com/f1rTXy8L
Unread 08-02-2016, 18:51
snekiam snekiam is offline
FRC #3322 (Eagle Imperium)
snekiam has a spectacular aura aboutsnekiam has a spectacular aura aboutsnekiam has a spectacular aura about
Re: Code not deploying properly?
Did you make any code changes? If your code is crashing on startup, it may show that no robot code exists on the Rio.
Unread 08-02-2016, 18:54
Dan Waxman Dan Waxman is offline
FRC #0263 (Aftershock)
Rookie Year: 2016
Dan Waxman is an unknown quantity at this point
You're trying to allocate two or more devices to one PWM port. Fix that and it should work.
Unread 08-02-2016, 18:59
FRC #6078
we don't have the PWM hooked up. A mentor from another established team said we probably don't need it.
FRC #6078
Here I'll post my code, I don't see why it would be crashing: https://github.com/Jajoo/RoboRams
Unread 08-02-2016, 20:06
Stimpy1901 Stimpy1901 is offline
AKA: Bobby
FRC #2348 (Cool Geeks)
Stimpy1901 will become famous soon enough
We had this same problem. We found the problem was assigning the PWM ports more than once (as Dan said). The RobotDrive can take motor controllers as parameters, so you would do something like this:
    	jagFrontLeft = new Jaguar(9);
    	jagFrontRight = new Jaguar(6);
    	jagBackLeft = new Jaguar(7);
    	jagBackRight = new Jaguar(5); //in your code, this was jagBackLeft again
        myRobot = new RobotDrive(jagFrontLeft,jagFrontRight,jagBackLeft,jagBackRight);
        //The above may not be the correct order as I do not have the Eclipse with me, but hopefully you get the idea
I do wish it would not compile and the error would be flagged sooner.
"The person who says it cannot be done should not interrupt the person doing it."
- Chinese Proverb
