Go to Post FIRST is kind of like charity work... you are, even if only in some small way, helping our future just a little bit, and you get a great feeling from it. Even if you are just ringing a bell (or clapping MOE sticks together), you're helping. - Amanda Morrison [more]
Unread 08-02-2016, 19:14
MaikeruKonare's Avatar
MaikeruKonare MaikeruKonare is offline
Programming Division Captain
AKA: Michael Conard
FRC #4237 (Team Lance-a-Bot)
MaikeruKonare is an unknown quantity at this point
Re: Microsoft USB Camera Error
Originally Posted by csilent View Post
CameraServer::GetInstance()->StartAutomaticCapture("cam0");
When using the USB Cameras I would suggest not doing automatic capture. The following is something I made that works. This code is for toggling between two USB cameras, because we have a front and back cam.
CPP File:
 * LHSVision.cpp
 *  Created on: Jan 26, 2016
 *      Author: Michael Conard
 *  THING TO CHECK:
 *  	-In Internet Explorer, roborio-4237-frc.local,
 *  	 confirm the camera names in Silverlight. These
 *  	 should be "cam0", "cam1", or "cam2".
 *  	-These names can be adjusted in the CAMERA
 *  	 namespace.
#include "WPILib.h"
#include "LHSVision.h"
namespace XBOX		//Joystick Constants
	const int NODE_ID = 1;
	const int XBOX_A_BUTTON  = 1;
	const int XBOX_X_BUTTON = 3;
	const int XBOX_LEFT_X = 0;
	const int XBOX_LEFT_Y = 1;
namespace CAMERA	//Camera Names
	const char* CAM_ONE = "cam1";
	const char* CAM_TWO = "cam2";
//NOTE: Camera 1 is the default camera. Can toggle to 2 later.
LHSVision::LHSVision(RobotDrive* pRobot, Joystick* pXbox) //Constructor
	printf("File %18s Date %s Time %s Object %p\n",__FILE__,__DATE__, __TIME__, this);
	frame = imaqCreateImage(IMAQ_IMAGE_RGB, 0);
	IMAQdxOpenCamera(CAMERA::CAM_ONE, IMAQdxCameraControlModeController, &session);
	Wait(.5);
	IMAQdxConfigureGrab(session);
	Wait(.5);
	IMAQdxStartAcquisition(session);
	Wait(.5);
	frame2 = imaqCreateImage(IMAQ_IMAGE_RGB, 0);
	mRobot = pRobot;
	mXbox = pXbox;
LHSVision::~LHSVision() //Destructor
	delete mXbox;
	delete mRobot;
//Used for closing and stopping acquisition of a camera
void LHSVision::StopCamera(int camNum)
	if(camNum == 1)	//Camera 1 Shutdown
		IMAQdxStopAcquisition(session);
		Wait(.01);
		IMAQdxCloseCamera(session);
	else			//Camera 2 Shutdown
		IMAQdxStopAcquisition(session2);
		Wait(.01);
		IMAQdxCloseCamera(session2);
//Used for opening, configuring, and starting acquisition of a camera
void LHSVision::StartCamera(int camNum)
	if(camNum == 1) //Camera 1 Startup
		Wait(.01);
		Wait(.01);
		Wait(.01);
	else			//Camera 2 Startup
		IMAQdxOpenCamera(CAMERA::CAM_TWO, IMAQdxCameraControlModeController, &session2);
		Wait(.01);
		IMAQdxConfigureGrab(session2);
		Wait(.01);
		IMAQdxStartAcquisition(session2);
		Wait(.01);
//Send image to FRC PC Dashboard
void LHSVision::SendToDashboard(Image *image)
	CameraServer::GetInstance()->SetImage(image);
void LHSVision::UpdateVision() //by Michael
	if(mXbox->GetRawButton(XBOX::XBOX_A_BUTTON) == true)	//Toggle on A button press
		while(mXbox->GetRawButton(XBOX::XBOX_A_BUTTON) == true)	//Prevents multi-press
		if(send == 1)
			StopCamera(1);	//Stop Cam 1
			StartCamera(2);	//Start Cam 2
			printf("\nActivating Camera 2 - Raw Image Display\n\n");
			send = 2;
		else
			StopCamera(2);	//Stop Cam 2
			StartCamera(1);	//Start Cam 1
			printf("\nActivating Camera 1 - Raw Image Display\n\n");
			send = 1;
	if(send == 1)
		IMAQdxGrab(session, frame, true, NULL);
		SendToDashboard(frame);		//Send Cam 1
		Wait(.1);
	else
		IMAQdxGrab(session2, frame2, true, NULL);
		SendToDashboard(frame2);	//Send Cam 2
		Wait(.1);
Header File:
 * LHSVision.h
 *  Created on: Jan 25, 2016
#ifndef LHS_VISION_H
#define LHS_VISION_H
class RobotDrive;
class Joystick;
class LHSVision
public:
	LHSVision(RobotDrive*, Joystick*); //Constructor
	~LHSVision();	//Destructor
	void SendToDashboard(Image*); //Send Image to Dashboard
	void UpdateVision();	//Toggle and Display Camera
	void StopCamera(int);	//Close Specified Camera
	void StartCamera(int);	//Start Specified Camera
private:
	IMAQdxSession session;
	Image* frame;
	IMAQdxSession session2;
	Image* frame2;
	RobotDrive* mRobot;
	Joystick* mXbox;
	int send = 1;
#endif
My Main File:
 * Robot.cpp
 *  This program requires:
 *  		-XBox Joystick
 *  		-Left Drive Talon
 *  		-Right Drive Talon
 *  		-Two USB Cameras on Roborio
 *  Ports can be adjusted below in PORTS namespace.
 *  Controls:
 *  	-Forward/Reverse, Left Y Axis
 *  	-Rotating/Spinning, Left X Axis
 *  	-Toggling Front/Back Camera, A Button
 *  Info: The cameras display to the FRC PC Dashboard.
 * 		  To open this: FRC Driver Station -> Third
 * 		  Tab (Setup) -> Set "Dashboard Type" to "Default"
 * 		  In the FRC PC Dashboard near the bottom-middle,
 * 		  change "Camera Off" to "USB Camera HW".
#include "WPILib.h"
namespace PORTS	//Motor Constants
	const int LEFT_MOTOR = 0;
	const int RIGHT_MOTOR = 1;
class Robot: public SampleRobot
private:
	RobotDrive* mRobot;		//RobotDrive with two Talons
	Joystick* mStick;		//Joystick
	LHSVision* mLHSVision;	//Raw Image Display
public:
	Robot();				//Constructor
	~Robot();				//Destructor
	void OperatorControl();	//Can Drive and Toggle Cameras
	void Autonomous();		//No Content
Robot::Robot()	//Constructor
	mRobot = new RobotDrive(PORTS::LEFT_MOTOR, PORTS::RIGHT_MOTOR);
	mStick = new Joystick(XBOX::NODE_ID);
	mLHSVision = new LHSVision(mRobot, mStick);	//LHSVision requires a RobotDrive and Joystick
Robot::~Robot()	//Destructor
	delete mRobot;
	delete mStick;
void Robot::OperatorControl()	//Driving and Camera Toggling
	while(IsOperatorControl() && IsEnabled())
		mRobot->ArcadeDrive(mStick->GetRawAxis(XBOX::XBOX_LEFT_Y), mStick->GetRawAxis(XBOX::XBOX_LEFT_X));
		mLHSVision->UpdateVision();
		Wait(0.02);
void Robot::Autonomous()	//No Content
	while(IsAutonomous() && IsEnabled())
		printf("Autonomous!\n");
START_ROBOT_CLASS(Robot)
I hope this helps. If you need me to simplify my code structure to do only one USB camera let me know.
