Go to Post As my boy Macklemore once said, "The greats weren't great because at birth they could paint, the greats were great because they paint a lot". - Andrew_L [more]
Unread 07-02-2016, 16:27
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Re: Team 2883 electoral board
Interesting use of energy chain, I like it. I'd be worried about that tight bend on the wire between the PDP and breaker- looks like it's being pinched quite a bit.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 08-02-2016, 19:43
generaldgibson generaldgibson is offline
generaldgibson
AKA: Daniel Gibson
FRC #3397 (FRC Robolions)
Rookie Year: 2015
generaldgibson is an unknown quantity at this point
I understand your pain of having a limited space... we're probably going to have a main electronics board about that size - if we're lucky
Unread 08-02-2016, 23:37
philso philso is offline
FRC #2587
Originally Posted by Sir_Fenwick View Post
This will be mounted on the top of our robot. We plan on using lexan and 3d printed parts to make a lid with access ports for the either net, fuses, breaker, etc.
How the board will exactly mount to the chassis is being debated. To get the tight radius on the wires, we bent them before crimping the connectors. This way, the stands were aloud to shift around the radius (the inside wires of the bend were longer then the outside, naturally). The CAN wire is longer then what it looks like, it is beneath the radio. All of the wires that leave the board are 2 feet long.
We had a discussion about pull testing the ends, and I can assure you that all of them were yanked on multiple times.
The battery connection has changed since the picture, it now bends around under the board were it will be mounted to a plastic block else on the robot.
That would be cool to see. The pull test got our electrical failure rate way down in the last two years.
I am currently working with my son to lay out our electronics inside our robot. With the mechanical design we have, it will be even more tight than what you have.
Unread 14-02-2016, 10:26
Looks very neat! The only thing I can comment on is the radio. This is a new radio so teams don't have a lot of info or in match data. However, the antennas for this radio exist just behind the sides of the radio so placing the radio near any metal will tend to attenuate the signals and provide serious reflections to the RF transmit circuitry. My recommendation is to place the radio high in your robot away from metallic structures for best performance.
Unread 14-02-2016, 11:51
mac mac is offline
AKA: Thomas (just give me a crabcake)McCubbin
FRC #0686 (Bovine Intervention/Jagbots)
mac is a name known to allmac is a name known to allmac is a name known to allmac is a name known to allmac is a name known to allmac is a name known to all
Mentor Mac here. More then likely it will fail inspection. You won't be able to see the lights on the radio by the FTA's and the Refs. 2nd You will bury the main breaker from easy access. That's a no, no, sorry. Thomas (just give me a crabcake) McCubbin God Bless
