Go to Post Mentors learn from, are inspired by, and emulate each other. A team with a great lead mentor leads to a productive, inspired, and ultimately successful group of mentors. - Jared Russell [more]
Unread 06-02-2016, 22:10
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Re: pic: Custom drivetrain
Originally Posted by pilleya View Post
It looks like your correct, so if this is the case and it is only 2CIM, then it will be interesting, that means that there is also 1/2 the friction area of the pulley against the tread, that I thought that there was. It looks like a BB 220 gearbox and while it is a rugged gearbox Banebots says " We recommend using a design that supports the end of the shaft", probably isn't a huge problem here as the wheel is close to the face, but something to be aware of
That robot breaching defenses might land on that cantilevered wheel, so the situation might be worse than what a normal drivetrain shaft would experience. Depends on if you're planning on going through tall defenses like the rock wall.
Unread 07-02-2016, 03:29
Happy Birthday! Tal_Esh Tal_Esh is offline
FRC #3316 (D-Bug)
Team Role: CAD
Rookie Year: 2015
Tal_Esh is a jewel in the roughTal_Esh is a jewel in the roughTal_Esh is a jewel in the rough
Excuse me for getting of the topic..
Was the orange box printed? and how?
Unread 07-02-2016, 03:44
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Nope, it was definitely not printed. It was probably just a container they had lying around
Unread 07-02-2016, 15:00
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
I'm guessing the orange box is a printer or typewriter cover.
I'm with Kevin on the traction. I had thought at first those were 2008 KoP wheels, but I see they're metal. You probably want to put some sort of rubbery coating like truck bed liner on those.
Unless I'm missing the scale (they look like 8" wheels) or the robot is too wide to get very far up the batter, scrub forces are going to be horrendous.
Unread 07-02-2016, 15:29
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I have serious doubts that this setup can actually move. Like literally, whether it will be able to translate motor power into forward motion.
I really, really hope you've tested this. Your interface between tread and pulley relying solely on friction (and not even having a V-belt interface or anything) is really, really bad as far as treads go. The suggestion to coat the pulleys in something with more friction honestly probably isn't even going to do the trick.
The moment someone T-bones you I don't see how your treads aren't immediately going to derail.
Not trying to be a jerk, just hoping you've already answered these questions so you don't show up to competition and have a season ending "OH SH**" moment.
2001-2004: Team 100
2006-Present: Team 254
Unread 07-02-2016, 15:39
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
The good news is if this doesn't work out, you're using the AndyMark KOP frame and can make a 6WD pretty quickly... But I'd agree with everyone else here. Run this through its paces at full weight on carpet.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 07-02-2016, 16:44
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Tippy
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 07-02-2016, 21:42
hectorcastillo's Avatar
hectorcastillo hectorcastillo is offline
Former Driver and Captain for 3481
FRC #0125 (NUTRONs)
hectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to all
Just curious, what is the pneumatic cylinder for? Also, it might be a good idea to put your compressor in your robot.
365 Decontaminators (FLL) 2011 - 2012
6221 Panther Bots Alpha (FTC) 2012 - 2016
3481 Bronc Botz (FRC) 2012 - Present
125 NUTRONs (FRC) 2017 - Present
Unread 07-02-2016, 22:08
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
I was the coach of my team in 2012 when we proudly posted our robot, and I remember the feeling when people started saying "what about the bumpers?". Fortunately for you, you have a week and a half more than we did to solve the problem. Also take seriously the advice about your tank tread design.
http://www.angelbotics.com
Remember why you're doing this.
Unread 08-02-2016, 12:17
Bertman's Avatar
Bertman Bertman is offline
FRC #0418 (Purple Haze)
Bertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond repute
Brilliant. Good luck with it.
success is not hocus posus, it's focus focus
Unread 08-02-2016, 16:26
Humberto fig's Avatar
Humberto fig Humberto fig is offline
FRC #4735 (DEROF)
Humberto fig has a spectacular aura aboutHumberto fig has a spectacular aura aboutHumberto fig has a spectacular aura about
We do have a V-belt and the pulleys with the proper adjustment. Actually we obtained the belts and the pulleys out of an air-conditioning device. And we have the proper tensors also. IT has been working great so far. Friction with carpet is the only thing that we have not tested but we are looking forward to test it on carpet today.
Also, we will add our bumpers to show it to you.
We know you are not trying to be rude we understand your point. This is Gracious Professionalism. Thank you for that!!!
http://imgur.com/LyEvxeX
http://imgur.com/FSPYEwj
Unread 08-02-2016, 20:20
MoistRobot's Avatar
MoistRobot MoistRobot is offline
AKA: Jon Charboneau
FRC #0832 (OSCAR)
MoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of light
Ahhh, nice.
Unread 08-02-2016, 23:04
FRC #4735 (DEROF)
Originally Posted by cbale2000 View Post
Is the entire system running off of just 2 CIMs (1 on each side), and are those planetary gearboxes they're driving (if so, what reduction)?
My biggest concern, in addition to the one mentioned above about getting enough traction, is whether or not you'll be able to turn at all with this. Generally the scrub on a high traction drive requires teams to use at least 4 CIMs on their drive system to avoid stalling their motors when attempting to turn.
We are using planetary gearbox, and there is no reduction
Unread 08-02-2016, 23:06
What is the ratio in the gearbox (and, also, from the gearbox to the driving point of the robot--this one is often by chain or belt)?
Unread 09-02-2016, 04:39
pilleya's Avatar
Elec+Mech
Wait hang on a minute, so is the planetary gearbox reducing the output speed of the motor?
I sure hope so, otherwise you will have many many problems
