Go to Post Once I see that it is black with aluminum ends, I only care about the inside. Sort of like Oreo's. - Al Skierkiewicz [more]
Unread 09-02-2016, 10:30
Re: What is PIDF?
Originally Posted by geniusadam69 View Post
I is integral, so sum (E) *Ki = output
D is derivative, so (E,now - E,last) *Kd = output.
I component = sum(err∆t)
D component = ∆err/∆t
since this thread is about PIDF (not just PID):
F component is a (usually experimentally determined) value (or values) that is added to the output. It can be a fixed value (if there is only one setpoint) or it can be in a lookup table or function within the controller.
