Go to Post Engineers crave and demand facts, and won't reach a conclusion without them. - Richard Wallace [more]
Unread 09-02-2016, 07:19
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
pic: MVRT's robot plan (95% done)
Unread 09-02-2016, 07:23
trumpthero786's Avatar
trumpthero786 trumpthero786 is offline
What Part of the Sandwich Are You?
AKA: Humza
FRC #2729 (Storm Robotics)
Team Role: Electrical
Rookie Year: 2015
trumpthero786 will become famous soon enough
Re: pic: MVRT's robot plan (95% done)
Thanks for sharing this with us. Looks great! Any reason you guys went for banebots on the shooter if you were going to gear them anyway? Also, is there something supporting the ball from underneath?
CLAP CLAP WHOOSH!
2015 - Hatboro Horsham - Quarterfinalist with 272 and 5181 - Entrepreneurship Award
2015 - Seneca - Quarterfinalist with 316 and 5684 - Engineering Inspiration Award
2015 - MAR Championships - 50th Seed - Quarterfinalists with teams 1923 and 11
2016 - Hatboro Horsham - Team Spirit Award
2016 - Seneca - Gracious Professionalism Award
"nice beaver tail"
Unread 09-02-2016, 10:28
Dinokaiz2 Dinokaiz2 is offline
FRC #4561
Dinokaiz2 has a spectacular aura aboutDinokaiz2 has a spectacular aura aboutDinokaiz2 has a spectacular aura about
Doesn't that intake have to start inside the frame perimeter? Does it articulate?
Unread 09-02-2016, 10:37
mastachyra's Avatar
mastachyra mastachyra is offline
FRC #2781 (RoboPride)
mastachyra is just really nicemastachyra is just really nicemastachyra is just really nicemastachyra is just really nice
You're going to wrap each individual noodle for your bumpers? Awesome!
JK, looks good
2014: EtaBot - MWR/30th place/no PO
2015: ThetaBot - MWR/30th place/no PO, R2OC/Winners, IndyRAGE 5th Alliance, WMRI QF
2016: IotaBot - MWR/16th place/QF, R2OC/7th Alliance Captain/QF, Boiler Bot Battle/6th place/Finalist
Unread 09-02-2016, 10:44
c.shu's Avatar
c.shu c.shu is offline
Alumni/Mechanical/CAD
AKA: Cole Shumaker
c.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to behold
What are you using to rotate your shooting mechanism back into your robot?
Unread 09-02-2016, 11:05
cad321 cad321 is online now
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
I can't tell specifically but if you look closely where the intake would pivot there are some gears showing. I'd imagine a versa planetary with a bag motor or similar.
There also appears to be a disc there. Possibly for a bike style pneumatic disk break?
Unread 09-02-2016, 11:12
Jarren Harkema's Avatar
Jarren Harkema Jarren Harkema is offline
Dancing Drive Coach
FRC #4967 (That ONE Team)
Jarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to all
That is one polished boulder!
I think I see the hooks for your scaling mechanism, are they supposed to be positioned where they are or are they supposed to be attached to the arms? Are you using a pulley lift or spring lift for the arm?
Unread 09-02-2016, 11:40
eghazal eghazal is offline
FRC #0503 (Frog Force)
eghazal is on a distinguished road
How are you guys planning on opening the Portcullis?
Also how do you guys plan on keeping your compressor held down on your robot? Alot of terrain defenses could make having a conpressor a hazard.
Anyways looks great!
Unread 09-02-2016, 13:00
lphung lphung is offline
FRC #5994
lphung is an unknown quantity at this point
Awesome CAD model
Unread 09-02-2016, 13:45
philso philso is offline
FRC #2587
Where will you be mounting your battery, main breaker and motor controllers? I would suggest you get the generic electrical schematic drawing and "follow the power flow" from the battery through the main breaker, PDP, motor controllers to the motors and lay out your components that way. Allow at least 1 inch around all sides of the main electrical components (RoboRio, PDP, PCM, VRM) for routing your wiring.
In your current design, the wires coming out of one side of your PDP will catch on one of the cylinders for your climbing mechanism. You will also have trouble getting the tool into the Wago's on that side. On the other side, the wires coming out of your PDP will have to run over the router. This will make it difficult and messy to remove your router for programming at each tournament you go to.
Can you use the empty space between your current electronics panel and the boulder collector mechanism or is that space reserved for future enhancements?
Unread 09-02-2016, 16:05
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Thank you for the compliments and suggestions!
Those are actually AM performance wheels with blue tread; we found that they shot better than the orange Banbots we had, and did not damage the ball. It also lets us swap out wheels/tread cheaply.
That's correct. We are using a 300:1 VP with BAG motor on each side of the shooter, with MA3 encoders on the rotary shaft. We may opt to try the Versaplanetary encoder instead, but we'll see if MA3s work first.
The shooter can articulate down far enough to open it.
We were planning on just using woodscrews or machine screws + threaded inserts to hold down the compressor.
The hooks are in the correct spot, and the spacers for them to attach them to the arms were not put in when I made this render.
We are using constant-force springs to extend the elevator/arm, and a pneumatic cylinder to flip it upright. A winch serves to retract it.
The battery is on its side right in the middle; it might be a little hard to see. The main breaker is the grey thing as we were unable to find an official model for it. The motor controllers will be mounted in various places, rather than just next to the rest of the electronics, to save space. They are mapped out as well, but not yet put in.
Thank you for the notes on the PDP placement, I did not think about the router issue. I was planning on just rotating it so it doesn't hit...
I just redid the electronics placement. Rest assured we have enough space for everything, but we have to place the motor controllers in the front of the robot.
