Go to Post They were designed that way so they would be compatible with the water-based ga.... oops, sorry, we aren't supposed to say anything about that. Never mind. - dlavery [more]
Unread 09-02-2016, 12:06
dmorewood's Avatar
dmorewood dmorewood is offline
Lead Designer / Coach
AKA: Drake Morewood
FRC #1218 (Vulcan)
Team Role: CAD
dmorewood is just really nicedmorewood is just really nicedmorewood is just really nicedmorewood is just really nicedmorewood is just really nice
Re: Rookie team in need of scaling advice
I agree and disagree with everyone else on this thread. Yes I don't think that for a rookie a climb is necessary or even that time efficient when you guys could be working on your shooter. On the other hand for the non rookie teams on this that think that a climb is not necessary to have a bot that people will want once you get to high level regionals and St. Louis...I completely disagree.
Unread 09-02-2016, 12:27
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
The WCP design is good to look at because it is one of the designs that deals with the most difficult part of scaling this year: Staying within your frame perimeter. If your robot tips it has to tip tail up toward the tower (and not too much) or you will quickly be out of your frame perimeter.
We have had some very successful climbing bots (in particular in 2004 and 2010) in the past, but put scaling at the bottom of our priority list this year because of its relative difficulty and relatively low point value. That said, if you have achieved most of your other goals there is no reason not to try to build a scaling device. It does not have to interfere with practice and other development. In 2010 we got an inexpensive manual winch from Lowes and took off the ratchet and sprocket. We welded the sprocket onto our winch spool (but you could use the spool from a winch and bolt on a hub) and attached the ratchet with a spring. Simple and effective.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
