Go to Post The programmers tend to get less credit than they deserve, but the robot wouldn't run if we weren't there. :) - IMDWalrus [more]
  #31   Spotlight this post!
Unread 09-02-2016, 12:17
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: New to FRC- You guys are all amazing!
Sounds cool Brandon, I'd love to snag one if theres any left.
Side note: I wonder how well a Hyper 212 Evo will cool a CIM motor... (Or the new access point we use this year, that thing gets hotter than I thought it would...)
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
  #32   Spotlight this post!
Unread 09-02-2016, 12:20
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
I have a couple laying around. Should I test
  #33   Spotlight this post!
Unread 09-02-2016, 12:28
AKA: Matt B
FRC #1771 (1771)
Sure, why not! Obviously it wouldn't be practical, but I could see teams needing to cool down the motors between matches during semifinals and finals.
1771- Mentor (2015)
  #34   Spotlight this post!
Unread 09-02-2016, 12:31
Sperkowsky's Avatar
Alright. Ill have it done this weekend.
  #35   Spotlight this post!
Unread 09-02-2016, 12:33
CMBrandon's Avatar
CMBrandon CMBrandon is offline
North America Marketing
Rookie Year: 2016
CMBrandon has a reputation beyond reputeCMBrandon has a reputation beyond reputeCMBrandon has a reputation beyond reputeCMBrandon has a reputation beyond reputeCMBrandon has a reputation beyond reputeCMBrandon has a reputation beyond reputeCMBrandon has a reputation beyond reputeCMBrandon has a reputation beyond reputeCMBrandon has a reputation beyond reputeCMBrandon has a reputation beyond reputeCMBrandon has a reputation beyond repute
I don't know if it would work that well. The 212 Evo works best against a flat surface.
  #36   Spotlight this post!
Unread 09-02-2016, 12:45
Sperkowsky's Avatar
The surface area would be decent on a CIM. Applying the right amount of thermal compound is the issue. Can't wait until you guys manufacture the CIM waterblock.
  #37   Spotlight this post!
AKA: Matt B
FRC #1771 (1771)
The back of the CIM motor is (mostly) flat, however most of the heat isn't dissipated from that location, but it does get hot after a lot of continuous use. Some thermal paste will definitely help instead of direct contact.
Anecdotal story: Last year the students were doing a demo, for several hours. Eventually the performance of the robot was quite abysmal. I noticed the motors were hot...REALLY hot. I took some damp paper towels and wrapped them around the motor...you could hear the water sizzle and evaporate off. So maybe CoolerMaster could make a water cooling block for CIM motors!
Edit: I see that Samuel had the same idea as me, and we posted at the same time.
1771- Mentor (2015)
  #38   Spotlight this post!
Unread 09-02-2016, 12:46
Sperkowsky's Avatar
You got sniped
  #39   Spotlight this post!
Unread 09-02-2016, 13:11
CMBrandon's Avatar
Rookie Year: 2016
Well let's think about this. The motor gets hot and it needs a way of dissipating the heat. I can think of 2 ways I would try to go about this based on skill, time, space, etc.
1- Take a heat-sink similar to this and drill out the middle. Slide it on the motor. The fins will carry heat away. Not the greatest, but it will help. http://www.coolermaster.com/cooling/.../x-dream-p115/
2- Take a liquid cooling system (closed loop) and disconnect the part that goes against the processor. Swap it out for a hallow cylindrical sleeve that fits around the motor. This would definitely take some effort and custom parts but it sounds like it might be worth it if it can be used every year.
Keep in mind I have never built a robot and have no idea what I'm talking about
  #40   Spotlight this post!
Unread 09-02-2016, 13:33
AKA: Matt B
FRC #1771 (1771)
Actually, your first idea kind of exists: http://www.andymark.com/product-p/am-2865.htm
If you can blow a fan over them, they are more effective.
As for your 2nd idea, maybe all teams should bring their gaming PCs with a custom water loop, and put it in the pits and cool the motors down between matches!
1771- Mentor (2015)
  #41   Spotlight this post!
Unread 09-02-2016, 14:05
CMBrandon's Avatar
Rookie Year: 2016
Maybe all teams should bring their gaming PCs with a custom water loop, and put it in the pits and cool the motors down between matches!
Well, you don't need a PC to run a water loop.
  #42   Spotlight this post!
Unread 09-02-2016, 17:21
Sperkowsky's Avatar
No you do not. Really all you need is a power source for the pump and fans. Which run over pwm/3pin something the robo Rio has. Water cooling robots is totally overkill but I custom loop would look sick. If anyone wants to sctuslly do this contact me and ill give you a good price on parts. Also if anyone needs a bitfenix prodigy m ill give it to you for free plus s&h I need to get rid of it.
  #43   Spotlight this post!
Unread 09-02-2016, 17:33
CMBrandon's Avatar
Rookie Year: 2016
Is anyone using Cooler Master products this year with their team? I'd love to hear about it and how it has worked out for you.
  #44   Spotlight this post!
Unread 09-02-2016, 18:28
Sperkowsky's Avatar
We have 212 evos in all of our pcs.
  #45   Spotlight this post!
Unread 09-02-2016, 19:14
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
My personal pc, often used by my team for cad, was made using a CM case and uses a 212 to cool the cpu.
Has cm considered attending the world championship? You'd be able to meet teams from every corner of FRC there and be able to learn quite a lot about the ethos of FIRST.
