Go to Post All I know is that last year in Philadelphi, our camera locked dead onto MOE (Team 365) and their flourescent green shirts during the matches. They might want to consider what would happen if they get pelted with balls during the autonomous period! :ahh: - Greg Marra [more]
Unread 02-09-2016, 01:31 PM
RadhikaTheFish's Avatar
RadhikaTheFish RadhikaTheFish is offline
FRC #3815
RadhikaTheFish is an unknown quantity at this point
Connection Failed Deploying Labview
We have tried deploying our program and after we built it and start to deploy it this message comes up:"Connection failed. The network address might be invalid or the target is not responding. " Anybody know?
Unread 02-09-2016, 01:42 PM
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is offline
FRC #1756
Bpk9p4 is on a distinguished road
Re: Connection Failed Deploying Labview
were you doing this over USB or wifi?
2015 Midwest Regional Finalist
2015 Central Illinois Regional Winner
2015 Newton Division Finalist
2015 Newton Quality Award
Unread 02-09-2016, 01:44 PM
FRC #3815
Through Ethernet,
Unread 02-09-2016, 02:19 PM
Bpk9p4's Avatar
FRC #1756
Have you updated your router software?
i would first try to deploy code while connected with USB. If that works i would then try it though Ethernet and watch on the driver station to see if you are loosing packets.
Unread 02-09-2016, 02:54 PM
hardcopi hardcopi is offline
AKA: Rich Lester
FRC #2959 (The Robotarians)
hardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud of
We have not had a lot of luck with the Roborio and ethernet as far as programming it. Wifi and USB deploy just fine though.
Unread 02-09-2016, 04:52 PM
JeffB JeffB is offline
FRC #5052 (RoboLobos)
JeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to behold
If you're successful with WiFi and USB, I'd expect the problem with the connection is related to the network settings on the PC for the LAN adapter.
It's likely you're pulling an IP address that matches the router when you connect by WiFi. USB always pulls 172.22.11.2 and creates a virtual network interface. Ethernet requires your PC to be setup to talk to the roboRIO. For this, modify the settings in Windows to make the computer's IP 10.TE.AM.# and subnet 255.255.0.0 and you should be able to communicate directly by Ethernet to the roboRIO.
Unread 02-10-2016, 07:11 AM
sraque's Avatar
sraque sraque is offline
AKA: Steve Raque
FRC #2614 (MARS)
sraque is on a distinguished road
Originally Posted by RadhikaTheFish View Post
Through Ethernet,
If ethernet, it must be to the radio, not to the Roborio directly.
Unread 02-10-2016, 07:44 AM
phurley67 phurley67 is offline
Programming Mentor
phurley67 is an unknown quantity at this point
In our experience the network ports on laptops are a common failure point after a season or two of frc use. Additionally we do communication errors from labview that are often resolved by just trying again.
Unread 02-10-2016, 11:08 AM
FRC #3815
Okay thanks guys, I'll try it out and tell you how it goes.
Unread 02-10-2016, 11:54 AM
BSV BSV is offline
FTC / FRC mentor
AKA: Travis
FRC #2723
BSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud of
We tried deploying via USB and get the same error.
Unfortunately we have only novice programmers and none of the mentors who are able to show up the next two weeks know anything about Labview.
Anything we should be trying?
Unread 02-10-2016, 02:14 PM
G_rupp's Avatar
G_rupp G_rupp is offline
FRC #1108
G_rupp is an unknown quantity at this point
Can you turn off the WIFI adapter? A lot of times, the computer will attempt to use the wifi connection instead of the wired or USB connection.
Unread 02-10-2016, 04:41 PM
FRC #3815
I've been having the same problems with USB much like @BSV
Unread 02-10-2016, 05:08 PM
FRC #3815
Does the radio need to be hooked up to deploy?
Unread 02-11-2016, 07:59 AM
You don't need the radio if you use USB for Run as startup . It's not in the path and doesn't give out the IP addresses used by the roboRIO or PC over USB.
If you are using Ethernet, then through the radio is easiest. The radio is assigning compatible IP addresses to both the roboRIO and PC.
The radio is necessary for downloading code over wireless, of course.
You can use Ethernet without the radio there to serve IP addresses, either connecting through a bridge or directly between the roboRIO and PC. In fact that's essentially how it will work in the pits at competition. At competition the robot's OpenMesh radio will be setup as a bridge and won't be serving DHCP addresses, which is the playing field AP's job. So, in the pits the PC and roboRIO will both resort to compatible default IP addresses in the 169. range.
The trick is that the roboRIO will take it's default address as soon as it boots and doesn't find a DHCP server. The PC needs to timeout it's IP assignment if it's been connected to a DHCP server in the recent past. Some PC's are quick to reassign when the DHCP server disappears, while others are slower.
Just be aware that it's going to be smoother if you avoid unnecessarily switching back and forth between connecting to the radio and connecting directly to the roboRIO via Ethernet.
Unread 02-11-2016, 04:58 PM
FRC #3815
Radio Issues
USB Didn't work so we are attempting to configure the radio, we've changed the IP Address in the control panel network ethernet check on Version 4. I changed it to 10.38.15.1 and when we try configuring it says our IP Address has not been changed, and when we check back on the ethernet control panel, it changed our IP Address to 192.168.1.51
Last edited by RadhikaTheFish : 02-11-2016 at 04:59 PM. Reason: Dis scrub behind me made me do it :(
