Go to Post I betcha the FIRST officials in the know come in here from time to time and either gasp and think of how to make next year's clue harder or fall off their chair laughing. - Sparks333 [more]
Unread 09-02-2016, 00:35
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
3019's preview of our "black knight"
we are getting there At least it looks nice. We have a pretty consistent shooter. More features are still to come
Unread 09-02-2016, 10:14
zinthorne's Avatar
zinthorne zinthorne is offline
AKA: Avery
FRC #5827 (Code Purple)
zinthorne will become famous soon enough
Smile Re: 3019's preview of our "black knight"
Are those bumpers 8 inches off of every corner? From the view it looks like the are shorter than that. Just want to check so you don't have a rude awakening at inspection.
Unread 09-02-2016, 10:44
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
We found with too much compression those bag motors will stall so be careful.
Unread 09-02-2016, 15:59
Head programmer
The front side does not actually have 8 inches of frame, so due to robot rules we only need that amount of coverage. We looked in the Q and A and they kept referring to the same rule about if a side is shorter then 6 inches
Unread 09-02-2016, 16:09
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
You are incorrectly interpreting the bumper rules. As stated in the manual, if you were to wrap a string around your robot, your frame perimeter would be the polygon created by that string. Regardless of whether or not an actual frame member is present across the entirety of the front of your robot, that line is your frame perimeter. Since that side of your frame perimeter is >8", you need at least 8" of coverage from each corner.
Unread 09-02-2016, 16:14
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
That's not how the 6 inch rules work think. See section 4.7; right under R19 there are four diagrams showing possible bumper configurations. The lower-left image shows your predicament clearly- you'll need to add more bumper on that side.
Unread 09-02-2016, 16:18
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
[R2]'s blue box describes a "string" test that will define your frame perimeter. All of [R19] is in reference to this frame perimeter and not the actual robot frame. That the frame is only 6" wide around your front wheels doesn't have anything to do with how the frame perimeter is defined. I encourage you to seek out further advice before moving forward with 6" of covered frame perimeter corners.
It looks like an extremely easy fix though, given a great and simple design.
GitHub
Unread 09-02-2016, 17:29
Bob Steele's Avatar
AKA: Bob Steele
I believe you are confused about the rule. The 6" rule is if the entire side of the frame is less than 8".... not just pieces of it. So if you had a robot that was 7" side (total) by 48" long... you could then get away without 8" of bumper on the 7" sides. Your robot is well over 8" wide in the front and back and will need to have at least 8" of bumper/support to pass inspection.
Unread 09-02-2016, 17:34
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
What everyone else said about having at least 8" of bumper. But also remember that you can't just make your bumpers 8" long. The end will also have to be supported by frame, so you'll need to extend the frame of your robot to 8" in those locations as well.
Unread 09-02-2016, 17:35
zinthorne's Avatar
AKA: Avery
The outside edge of your rhino track is defined as a corner. The rule states you need 8 inches of bumper extending out from every corner.
The 6 inch rule is for if you have a robot shaped like thishttp://blogs.solidworks.com/teacher/...-regional.html scroll a few paragraphs down to the picture without the bumper. They have a side of frame less than 8 inches, so they only need 6 inches of bumper, but then they also have 8 additional inches of bumper off of each corner.
Unread 09-02-2016, 18:00
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
You also might consider having more than one CIM per drive train side.
Looks really nice-- hopefully it will be as fun to watch as it is to look at!
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 10-02-2016, 00:08
Head programmer
Wow...geez im just the media guy this year (kidding but not...) I actually just looked over the rules and will have to inform my team of this unfortunate mistake we made. In the beginning of the season they did keep saying that if a side was shorter then 8 inches it just has to be covered...I looked at the q and a and the updated manual again...Definitely not one of the rules that should have been vague...
I am interested how some teams did solve the problem?
Unread 10-02-2016, 00:51
scca229 scca229 is online now
FTA acquiring knowledge
AKA: Nate
FRC #0060
scca229 has a spectacular aura aboutscca229 has a spectacular aura about
Also remember that it is 8" of frame length from the corner that has to be covered, not the outside measurement of the bumper itself, which will be longer since it has to go past the corner to mate up with the adjoining side bumper. The corners at the back of the image do not look to be covering 8" in either direction down the frame from the corner. The close ones could also be too short down the sides but not sure. Perspective of the image is making it a little tough to tell.
Nate
Unread 10-02-2016, 00:52
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
We made a 30" wide robot and raised the bumpers so that we could get up onto the batter, as well as have a 13.5" cutout (1/2" of leeway).
Unread 10-02-2016, 11:51
Andy A. Andy A. is offline
Getting old
FRC #0095
We've accumulated 6 pages of bumper rules in the manual. Trust me; yours isn't the only team to have made a mistake with bumpers. It's happened before, it's happening right now, it'll happen in the future. I dream of a day that a first week event can get through inspection day without any bumper violations, but I kind of doubt that's going to happen anytime soon.
I guess we can't blame FIRST for the crazy bumper rules though. At least half are there to eliminate loop holes and sneaky optimizations teams have come up with over the years.
