Go to Post Now please, go have some meaningful discussions that will inspire us all. - Ken Leung [more]
Unread 09-02-2016, 18:51
Sparx030 Sparx030 is offline
FRC #1251
Sparx030 is an unknown quantity at this point
Potentiometer Suggestions
What would be the best type of potentiometer to get for an arm that will move between half to one revolution, and check whether the arm is positioned up or down. The mounting location would be directly on the arm axis. I don't know if i'm missing information but if you need it I will get it.
Unread 09-02-2016, 18:53
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Re: Potentiometer Suggestions
I prefer these.
http://www.andymark.com/product-p/am-2899.htm
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 09-02-2016, 23:48
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Potentiometers with much more than 1/2 turn are unusual, though there are a few, such as this 10-turn pot from Jameco. Less expensive than an absolute encoder, but you'll lose most of the dynamic range as you're only using one revolution, and it's easier to break. OBTW the sweep is the contact farthest from the shaft, not the one in the middle like most pots.
Unread 10-02-2016, 00:07
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
more than a half turn is unusual? That's not been my experience...
Go to Digikey, and put in your search terms on their potentiometer page. You can get anything from 230 degrees to 3600 degrees rotation, including continuous turn pots.
Personally, I look at what we need for the application, add a bit for safety (no sense breaking it by trying to turn it too far), and order what we need.
2016: Lake Superior WFFA
Unread 10-02-2016, 08:26
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
I didn't mean rare. The point is that if you want more than half a turn you're going to have to specifically identify potentiometers with that feature, not just pick one up out of the bin of generic parts or hit radio shack.
