Go to Post Cooling fans? Never had the need. Then again, we're talking New Jersey in March. Radiant heaters might be a better choice, or maybe snow boots. - DonRotolo [more]
Unread 09-02-2016, 19:07
2386programming 2386programming is offline
FRC #2386 (Trojans)
2386programming is an unknown quantity at this point
Button not working, axis are.
We are trying to control our functional mechanisms using buttons on our controller. The problem that we have though, is that when we try to control it using buttons, the motor keeps rapidly turning on and off (basically twitching). When I map the control to an axis though. It works flawlessly. Using Labview.
Unread 09-02-2016, 19:28
FRC #2386 (Trojans)
Re: Button not working, axis are.
When we use one case structure saying if button is true then turn on motor, if false then set output to zero. the moment we add another case structure to control the motor in the other direction, it starts twitching.
Unread 09-02-2016, 19:30
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Sounds like you're setting the output to the motor twice. You need to make sure you only set the output of the motor once in your loop.
If you can post a picture or snapshot of your code, we can tell you more exactly how you're going wrong.
Unread 09-02-2016, 19:42
FRC #2386 (Trojans)
Here ya go
Unread 09-02-2016, 21:11
Okay, I was hoping someone else would show up to draw up the correct solution, since I don't have Labview installed at the moment.
Anyways, you're definitely setting the output for the motor twice, because you have a set output VI in each of those case structures. To fix that, you need to do two things:
1. Only use one set output VI per motor. Delete all the Set output VIs in those case structures. Put one Set Output VI outside the case structure.
2. Use values inside the case structures to feed the Set Output VI. You want one big case structure with +1 inside the TRUE case, and ANOTHER small case structure inside big one's FALSE case. Then, put a -1 in the TRUE case of the smaller structure, and a 0 inside the FALSE case of the smaller structure.
I'll try to hack up a drawing in Paint or something since I don't have Labview. Or maybe we'll get lucky and someone with Labview will wire up what I just described. Feel free to post a screenshot of your attempt at what I just described there.
Unread 09-02-2016, 23:17
Here's an example using buttons to drive a motor.
http://www.chiefdelphi.com/forums/at...6&d=1454729278
Unread 10-02-2016, 16:55
FRC #2386 (Trojans)
Great! Thank you very much! I'll give this a try.
Unread 11-02-2016, 12:26
FRC #2386 (Trojans)
It's not working for me, tell me if this looks right.
Unread 11-02-2016, 12:30
Sorry,
That will work as long as you continue to hold a button down.
As soon as the button is released the motor will stop.
Do you want something different to happen or is the motor still pulsing?
Unread 11-02-2016, 12:38
aeastet aeastet is offline
Programming Mentor
AKA: Tim Easterling
FRC #6043 (Allegan Tigers Robotics)
aeastet is an unknown quantity at this point
Did you register the mew motor controllers in the begin.vi?
This should work as long as each motor was set up in the begin file and has a unique PWM was selected for each motor. If it still is not working make sure that you have the correct button on the joystick selected.
If you put one motor control in the loop does it run?
Unread 11-02-2016, 12:55
FRC #2386 (Trojans)
I have them all initizlized in the begin.vi
The 3 controllers being used are a talon srx, talon, and victor. My problem is that only one motor turns with one button.
Unread 11-02-2016, 13:18
Programming Mentor
AKA: Tim Easterling
Can you show the begin file where these VI's are registered?
Unread 11-02-2016, 13:26
Programming Mentor
AKA: Tim Easterling
OK As I started looking at your code I notice a few things:
You have two inputs going to each motor controller. For the first one called "ArmPivot" You have button 3 on the joystick controlling the first t/f vi. and you have you have button 1 controlling the second t/f vi. Are you sure that you are getting the expected result for both of these values?
Do you know how to use a probe int he software? That would tell you a lot about what is going on. If you probe them and pull the trigger then you should see the probe value to change and you will start to be able to troubleshoot what is going on.
Unread 11-02-2016, 13:37
Programming Mentor
AKA: Tim Easterling
Look at this as well.
Unread 11-02-2016, 14:41
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
Also I notice you don't have a button labeled zero (0). Just to be sure, the button marked one (1) on your gamepad is actually button zero (0) in the code. Arrays are weird that way and could affect the way the buttons operate versus what you want them to do.
