Go to Post I don't get what all you people have done wrong to make the drills have so many problems. - Cory [more]
Unread 08-02-2016, 19:41
dszlucha dszlucha is offline
FRC #1518 (Raider Robotics)
Rookie Year: 2016
dszlucha is an unknown quantity at this point
How to run GRIP in headless mode on the driver station?
Hello!
I'd like to be able to run GRIP in headless mode on the driver station such that the drivers can log in and GRIP starts up along with our vision pipeline without having to navigate the GRIP menus to load the .grip file.
Are there command line options for GRIP to 1. start in headless mode and 2. automatically load and run a .grip pipeline?
Thanks!
David
Unread 08-02-2016, 22:57
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
Re: How to run GRIP in headless mode on the driver station?
I think this should work. Run this from a command prompt.
java -jar C:\Users\USERNAME\AppData\Local\GRIP\app\core-1.2.0-all.jar [MY_PROJECT.GRIP]
You should get something like this:
Loading Dependency Injection Framework
Feb 08, 2016 11:01:56 PM java.util.logging.LogManager$RootLogger log
CONFIG: Configuration done.
CONFIG: GRIP Version: 1.2.0
platform: /Linux/amd64/
Feb 08, 2016 11:01:57 PM edu.wpi.grip.core.Main start
INFO: Loading file test.grip
INFO: SUCCESS! The project is running in headless mode!
Feb 08, 2016 11:01:57 PM edu.wpi.grip.core.PipelineRunner$1 startUp
INFO: Pipeline Starting
GRIP (Graphically Represented Image Processing) - rapidly develop computer vision algorithms for FRC
Unread 09-02-2016, 19:52
Rookie Year: 2016
Hi Thomas.
Unfortunately I get an exception when I try to run GRIP in headless mode on Windows:
C:\Users\David>java -jar C:\Users\David\AppData\Local\GRIP\app\core-1.2.0-all.jar test.grip
Exception in thread "main" java.lang.IllegalArgumentException: Unknown signal: HUP
at sun.misc.Signal.<init>(Unknown Source)
at edu.wpi.grip.core.Main.main(Main.java:39)
I tried setting CLASSPATH to the C:\Users\David\AppData\Local\GRIP\app directory and got the same error.
David
Unread 09-02-2016, 20:48
FRC #0237
Oh, I guess you can't run in headless mode on Windows. SIGHUP is a unix-specific signal, but it's not really essential that it works except when it's running from the deploy dialog. I can fix it for the next release.
Unread 09-02-2016, 21:15
Rookie Year: 2016
Sounds good. Looking forward to an update.
Thanks!
David
Unread 09-07-2016, 14:08
MaskedBandit1 MaskedBandit1 is offline
MaskedBandit1
AKA: Anurag
FRC #2383 (Ninjineers)
Rookie Year: 2015
MaskedBandit1 is an unknown quantity at this point
Hello, just wondering if there was ever any solution that was released allowing you to run grip in headless mode on driver station computer. Also, just to be clear, when you run GRIP on ds computer headless, you do not need a coprocessor on the robot such as a pi or jetson board correct? Thank you. I appreciate any forthcoming answers.
Unread 09-07-2016, 20:40
FRC #0237
Yep, this was fixed a while ago
