Go to Post If mentors don't respect the students' desire to learn and take an active role in the construction, they're missing the point of FIRST. If students refuse to accept the knowledge and experience of the mentors, that's not independence - it's arrogance. - DB213parent [more]
Unread 09-02-2016, 22:44
mshafer1 mshafer1 is offline
Programming Mentor
AKA: Matthew Shafer
FRC #3937 (Breakaway)
mshafer1 is an unknown quantity at this point
Re: Problem with drivetrain and we can't figure it out.
Originally Posted by Shaif View Post
I noticed it said brownout protection on the dash whenever the problem occurred so we switched out the battery and everything seem to go a little better. We no longer loose connection from driving the 4 motors but out of curiosity how many CIMS can we drive at the same time at full power?
It depends on a lot of things. Including the gear reduction, and weight of the robot - on top of that, if you have enough CIM's running, your robot will be able to move, but no for very long because it would drain the battery.
If you want a more technical answer (I could work the numbers for you, or document how to do it for you), let me know (reply, private message, or email). I recently did a bit of research into gear box design for the sake of an engineering project, and have developed some tools to allow me to quickly analyze a motor/gear ratio/robot weight combination. I also have a stack of references available if you would like to do your own research.
Unread 11-02-2016, 01:39
Shaif Shaif is offline
FRC #5580 (SQUAD)
Rookie Year: 2015
Shaif is an unknown quantity at this point
Replacing the battery fixed it oddly. Thanks for the help guys!
Unread 11-02-2016, 09:01
You should test that battery (3 amps for 2 hours while monitoring voltage works nicely).
Unread 11-02-2016, 09:27
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
How old are your batteries? We find they last maybe three seasons. We hold aside new batteries for competitions and dont use them for practice or debug. I strongly recommend investing in a "battery beak" http://www.andymark.com/product-p/am-0995.htm
We use it at the beginning of every season to test every battery.
Unread 11-02-2016, 09:34
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
It's very common to find the "low battery" issue causing a few posts every year on CD. It seems to take some teams a while to figure out that you have to charge the batteries often! And that the FIRST thing to do when you have odd, unexplained robot performance, is to glance at the battery voltage reading on the driver station. If it's less than 12.5 v when the robot is enabled, but not doing anything, then you need a fresh battery.
