Go to Post Football has been a school institution for over 100 years--we can't expect FIRST to show the same potential in a 10th of that. - Petey [more]
View Poll Results: Is the low bar worth it or not?
yes 256 78.29%
no 71 21.71%
Voters: 327. You may not vote on this poll
Unread 08-02-2016, 15:51
anishde's Avatar
anishde anishde is offline
FIRST? What's SECOND?
AKA: Anish De
FRC #5123 (Mechadogs)
anishde is on a distinguished road
Re: Low bar or not
Originally Posted by GeeTwo View Post
Are you an inch under 16, or an inch under 14? The low bar is located at the neutral zone end of the defense, which means that you will need to be significantly shorter than 16 inches on your leading edge as you pass under hte low bar.
(I use the term leading because we have tried to eschew use of front and back for our robot. It will cross different defenses in different directions. We have a boulder launch that projects the boulder at the high goal from the opposite end of the pickup. Our robot ends are "pickup" and "launch" rather than "front" and "back".
Our height is 14.9 inches, give or take. We have a definite front and back to our robot because of our use of an arm, but we're alternatively looking at approaching the low bar from the back while going in to the courtyard, and the opposite for exiting the courtyard.
Since the defense isn't all that big, how big is the difference in a structure being closer or farther to the neutral zone? And will it make that much of a difference trying to pass underneath it?
Unread 08-02-2016, 15:59
Chris is me's Avatar
AKA: Pinecone
Re: Low bar or not
Originally Posted by JohnFogarty View Post
It is very much late in the season for this kind of decision to be made in my opinion.
On the contrary, I expect the majority of teams in FRC to make this decision in Week 5 or Week 6 of build season.
I think most teams have decided to go for it, but many, many teams will learn during testing that they are not very good at it, that Mechanism X interferes, that they have to drive slowly / in a specific way to go through it. At this point, some teams will see an opportunity to be better at X / Y / Z aspect of the game in exchange for not being able to go under the low bar. For many it will be hanging. For others perhaps a more accurate shooter will work with extra height. Maybe the mechanism teams use to go through other obstacles just can't tackle the low bar for some reason.
Now is when teams need to be thinking about "is it worth it", because the end of the season is when teams tend to break from their strategic objectives. Teams who "should" be keeping low bar functionality WILL give it up for the sake of keeping a "cool" mechanism, and teams who "shouldn't" be keeping the functionality will at the expense of the rest of their robot. It'll happen for sure, so we should have an informed discussion as to what robots should keep this capability and why rather than shutting down people for being "too late".
(The painful thing about this decision is that, if teams that abandon the low bar decided to abandon it from Day 1, they would be much better at every other aspect of the game simply because of the loosened constraints. The jack of all trades is the master of none, after all, and this is a classic case where over-reaching can hurt a team's season)
Unread 08-02-2016, 16:20
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Low bar or not
Originally Posted by c.shu View Post
Depends on how good your packaging guru's are.
It is possible to fit everything you need to play the game under the low bar. You just have to plan for the space for each mechanism beforehand rather than look for space when you get around to it.
It is on the cusp of maddening insanity to attempt to fit EVERY mechanism under the 15" while designing and working to being the BEST at something*. I will have a lot of respect for a team which stays under ~15" and can play every aspect of this game with any level of repeat-ability.
The really nice side effect is that even with large 8" wheels and a high ground clearance, c.g. is very low given the decision to attempt the low bar. In fact, I can move our battery from it lowest-mountable point in the frame to above the drive train transmissions and shift c.g. up by only about 1/8" (according to CAD...).
*Something being pick one: Scaling ; High Goal ; Low Goal ; Defense (point prevention) ; breaching ; Autonomous
GitHub
Unread 09-02-2016, 10:57
c.shu's Avatar
c.shu c.shu is offline
Alumni/Mechanical/CAD
AKA: Cole Shumaker
c.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to behold
Re: Low bar or not
Call us insane then. (we are at 14.5" right now)
Unread 09-02-2016, 11:44
JesseK's Avatar
FRC #1885 (ILITE)
Re: Low bar or not
We're right there with you.
We pushed to 15". Slowing down a bit to go under is our tradeoff for the extra critical 0.5" of height for a certain mechanism.
On the plus side, the portcullis doesn't have to be raised that far
GitHub
Unread 09-02-2016, 11:48
catacon catacon is offline
FRC #1444 (Lightning Lancers)
catacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to behold
Re: Low bar or not
Yuuuup. We're a bunch of madmen also. The 2016 robot will certainly be our most dense robot ever.
Unread 09-02-2016, 12:11
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Re: Low bar or not
We are currently at 13". No climber yet, but we will see.
http://www.angelbotics.com
Remember why you're doing this.
Unread 09-02-2016, 21:14
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Low bar or not
we finally got the robot mostly working today...and tried it on the low bar. It fit.
https://youtu.be/8ZeExbmZBVA
Unread 10-02-2016, 00:05
bowmanb bowmanb is offline
AKA: Bruce Bowman
FRC #3991 (KnightVision)
bowmanb is an unknown quantity at this point
Re: Low bar or not
LOL, we were constantly arguing over which end is which. We finally came to the same kind of terminology compromise, although ours is "intake" and "shooter"
Unread 10-02-2016, 00:19
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Very nice. We look like we have similar bots. Except we have an articulating shooter and a climber. See you in NYC.
Unread 10-02-2016, 00:42
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Re: Low bar or not
I have a hard time finding somethings value or worth until I either have overwhelming evidence that indicates how a scenario will run, or I have run the scenario and just found out that it is worth.
The big thing though is if you pin yourself to this big (or technically small) of a constraint, then you better be utilizing it fully to your advantage otherwise you might be making sacrifices for nothing.
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
Unread 10-02-2016, 01:03
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Low bar or not
Those are good points. However for my team at least, we found that we could fit everything under the height limit and still perform well. At times I have wanted to completely rework the design, but working through it has definitely paid off.
At the very least it gives us the option of going under, and to change our strategy. It's easy to get tall, but it's hard to stay short.
Unread 10-02-2016, 07:19
lovelj's Avatar
lovelj lovelj is offline
FRC #3824 (RoHawktics)
lovelj is an unknown quantity at this point
Re: Low bar or not
Yup, lots of nuts in the nuthouse. We are definitely nuts. Another camera angle...
Low robots force discipline. You are either going to have a rats nest which is unreliable or a very tight robot which can survive. This is going to be a rough game. Sadly, no printed robot for 3824 this year... Cracked the frame week 1. If this is a fast game, loads on structural members will be the highest we've ever experienced.
Mentor: FIRST Team 3824
Oak Ridge National Laboratory
Manufacturing Demonstration Facility (MDF)
http://web.ornl.gov/sci/manufacturing/
Unread 10-02-2016, 16:42
bearbot's Avatar
bearbot bearbot is offline
FRC #2849 (ursa major)
bearbot is just really nicebearbot is just really nicebearbot is just really nicebearbot is just really nicebearbot is just really nice
Re: Low bar or not
We have figured out the low bar and Groups A,B and D and have a shooter that can go high or low. Still working out and working on our climber concepts but that was the lowest our list of to dos .
FRC Events:
Chesapeake Regional Rookie inspiration award 2009
Offseason Event:
Battle O'BAltimore Champions 2010
FRC Teams :
2849 Ursa Major (Student 2009-2011) (Mentor2011- Current)
5979 (Mentor 2015-Current)
Unread 12-02-2016, 21:20
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Low bar or not
Depending on your wheelbase and where the high spots are, this may be too tall because of the ramps coming and going. See this thread for details.
