Go to Post I don't know, there's quite a few teams that apply to travel to some random HS gym in Indiana every summer. - GaryVoshol [more]
Unread 10-02-2016, 08:14
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Best way to make gussets?
If a drill press is your only tool, you can use 0.1" perf board as a template, at least for right angles (you can also use it for 37/53 degree angles, you know a 3-4-5 right triangle). Mark the holes you're going to drill, clamp, and match drill 1/16" pilot holes using the perf board, remove the template, then follow up with your rivet/bolt size. I've also used this trick for laying out control panels and LED arrays - nice even spacing with little fuss.
Unread 10-02-2016, 08:30
Back after 4 years off
FRC #5279
Clever, definitely adding this to my bag of tricks.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 10-02-2016, 09:12
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
We use CAD, dial calipers, a band saw, center punch, and drill press. It is not a fast process, but it is successful about ~70% of the time for simple parts like this, and give our students some good experiance.
Unread 10-02-2016, 09:35
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
This is, in my opinion, one of the big drawbacks of pre-machined holes in parts. It's rather time consuming to get everything to lineup properly when you have to make anything custom to interface with it. It's probably the biggest reason my team has moved away from pre-machined holes. Everything we use is simple extrusion, then you just clamp your gusset on it, drill a couple holes through both pieces at the same time, and bolt/pop rivet it in place. Your holes always line up that way, and if you want a nice clean look you just need to properly mark your spacing on the top piece before you drill.
2016: Lake Superior WFFA
Unread 10-02-2016, 09:42
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
We get some free waterjetting through one of our main sponsors, Caterpillar. However, the slow turnaround time for waterjet can be very limiting. We recently got a very simple (and very unforgiving) tabletop sheet router, for doing quick mockups and prototypes. It's very sensitive to calibration, and basically everything else, and it isn't nearly as accurate as waterjetting. However, it's nice to be able to whip up a custom gusset out of MDF in a matter of 10 minutes, to make sure it fits the way it should.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 10-02-2016, 12:25
Gdeaver Gdeaver is online now
FRC #1640
We have been cutting .125 Al 6061T6 on the X-Carve. It does take some dialing in to cut AL. We need to do some mods to be able to cut faster or with more precision. For gussets it's fine. For real precision we need to go to true cam software. Something to master after the season.
Unread 10-02-2016, 12:34
Nebster's Avatar
Nebster Nebster is offline
AKA: Ben Kishter
FRC #1306 (BadgerBOTS)
Nebster is an unknown quantity at this point
Good to know. My team recently won a grant for the 1000x1000 x-carve, it just came in and we haven't assembled it yet. Did you upgrade the router that came with it? Our main shop mentor seems to think it will not cut aluminum well enough even for gussets and things.
2015 Wisconsin Regional Chairman's Award - Carson Division
2013 Wisconsin Regional Chairman's Award - Curie Division
Unread 10-02-2016, 12:37
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
In a pinch I will work with the students to print a part 1:1 scale and use it as a direct template. Tape it to the part, use a punch to mark the holes and then head to the drill press and bandsaw.
Unread 11-02-2016, 08:08
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is offline
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
jkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of light
I'm working on a white paper for the end of build season about the xcarve. So far, it has cut everything on our robot. Bellypan, gussets, tube, etc
Cortechs Robotics 2014-Present
Mechanical, CAD
Unread 10-02-2016, 12:38
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Mcmaster Carr has a nice set of inexpensive brackets you can buy that can work out for you.
http://www.mcmaster.com/#framing-bra...ctors/=112dxpw
A tool that is a great thing to have is a cleco tool. It's a temporary hole clamp used to align parts when we match drill.
http://www.mcmaster.com/#=112dz4u
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 10-02-2016, 12:43
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Originally Posted by roystur44 View Post
A tool that is a great thing to have is a cleco tool. It's a temporay hole clamp used to align parts when we match drill.
+1 to Cleco Tools! We have three Cleco Pliers and hundreds of Clecos. Everything we assemble gets cleco-ed before being riveted together.
-Mike
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 10-02-2016, 12:47
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Thanks for the ideas! We have a sheet metal sponsor, but they do not like to do things other than 90* angles for the sides of gussets, so I was hoping there was a quick way to make them by hand. They also only do 1-2 big orders for us each season as it's faster for them to do that than a bunch of orders for 4-8 gussets each.
Normaly we do what Mrnoble said (print, drill, cut) but the paper peels sometimes, and it tends to be rather slow if we need to make 16 or 30 gussets.
Unread 10-02-2016, 14:00
jijiglobe's Avatar
jijiglobe jijiglobe is offline
FRC #0694
jijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant future
In the case of many gussets, you just need to make sure the holes line up. you can actually accomplish this by clamping the two parts you want to attach together, throwing them on a drill press, and going through. By doing this you can attach two pieces without spending basically any time lining up holes.
RoboRio
Rob/oRio
oRio
photo credits to Greg McKaskle
Unread 10-02-2016, 14:39
OccamzRazor's Avatar
OccamzRazor OccamzRazor is offline
Go YETI!
AKA: Robbie
FRC #3506 (YETI)
OccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to behold
If you have no waterjet or laser access we have used this engraving tool to trace the edges of the part from a drawing to transfer it to the surface of the metal:
http://www.homedepot.com/p/Dremel-12...0-01/100394725
It works well if you place a drawing onto the metal sheet and trace around it or make a straightedge with a piece of scrap. Takes a minute or so to trace the outline and it is usually accurate enough to make one to scale properly. We learned our lesson last year and match drill everything that is not the proper gusset from VexPro. We line up one hole, stick a rivet in with the gun, and then drill the rest of the pattern.
2015 NC Regional Chairman's Award
2016 NC Guilford District Event Winner
2016 NC Guilford District Chairman's Award
2016 NC District Championship Winner
2016 NC Regional Chairman's Award
2016 NC Woodie Flowers Award Finalist - Lia Schwinghammer
Unread 10-02-2016, 16:28
Michael Hill's Avatar
We use a sheet metal shear to cut triangles. Clamp, drill, cleco, rivet.
