Go to Post Incidentally, this is a good example of why lawyering the FIRST rules is good practice for the real world. By critically analyzing FIRST's errors, you practice for the day when you need to critically analyze legislators' errors (and deliberate trickery). - Tristan Lall [more]
Unread 10-02-2016, 03:21
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Best way to make gussets?
I've tried to avoid using anything other than "standard" Vex gussets this year, but some parts just need the extra strength that a triangle gives you. My question is, how do other teams handle making gussets? The fastest way I have found to make them accurately enough to fit onto a machined hole pattern is to use the table saw to get outside dimensions, clamp ~10 at a time together and mill the holes, and use a bandsaw to get the final contours. The whole process takes about 3 hours to make a set, but requires an experienced member's constant attention and takes up valuable mill time.
We have tried printing out the gusset and gluing the paper to aluminum before drilling, but it often peels off, and it's hard to do multiple at once this way.
Unread 10-02-2016, 03:33
TheHolyHades1 TheHolyHades1 is offline
TheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the rough
Re: Best way to make gussets?
My team has access to a waterjet through one of our sponsors, so we send out a fully laid out dxf and stock to get turned into gussets with fairly quick turnaround. It's basically as easy as lasercutting, and significantly cooler.
If that's not an option, a few ideas come to mind. They'll vary in their effectiveness based on how precise the parts need to be.
1. If you have access to a tabletop lasercutter, you can cut out gussets from cheap material such as 1/8" plywood, and then transfer holes onto metal from there. Use a mill to cut out the profile and drill holes. This will obviously be the most precise, but also the slowest.
2. Using the above method, you can also probably use a hand drill to do the holes, since you'll have them punched. Then, use a bandsaw / jigsaw to cut out the shape. I'm partial to a jigsaw, myself.
3. Cut out a shape for the gusset from stock however you want, and then clamp it directly to the pieces that need to be joined. Drill through both the gusset stock and the material to be joined in one go, rivet / bolt, and repeat. Your parts almost certainly won't be interchangeable, but it'll might also be the quickest method.
Unread 10-02-2016, 03:34
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
IMO,
I would just fundraise a little more and pay a shop to just do them for you. One year we paid a shop to waterjet about 200+ parts in various sizes and did about 1.5 sheets of work and came out around $800. This rate was a discounted rate for high schools, since then we have just found sponsors to help us out.
R.C.
MadTown Robotics Team 1323
Unread 10-02-2016, 04:22
KohKohPuffs KohKohPuffs is offline
The one with the punny last name
AKA: Daniel Koh
FRC #0299 (Valkyrie Robotics)
KohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura about
We have access to a CNC machine (is there a difference between a CNC router and a CNC mill, or are both the same), and the final product of the gussets we make with it is fairly decent after some deburring.
-KohKoh
115 MVRT, Driver (2013-2015)
649 M-SET, CAD (2015-2016)
299 Valkyrie Robotics, Mechanical Director (2016 - present)
Unread 10-02-2016, 06:48
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Originally Posted by R.C. View Post
IMO,
I'll +1 this. Being able to offload gussets to a third party really helps our workload during the season. We have a laser cutting sponsor up here that usually has 24-48 hour turn around time on parts. We usually have most of our gussets and bellypan done on the laser.
If you need to make gussets in house, I believe most time efficient and cost effective solution is CNC Router. We love the Velox 5050 CNC Router and it does wood, plastic, aluminum sheet no problem. With some patience it even does aluminum billet fairly well! (We made some custom 7075 #35 chain sprockets this year on it. Worked great!) it'll set you back 6k, but it's a great tool that is fairly easy for students to learn and get good at.
Before we had access to these resources, the paper drill template was a good go-to. If you are making a similar hole pattern to to the vex gussets, you can always use the COTS gusset as your hole template. I will often use an old gusset lying around as a drill template when prototyping or making parts quickly.
Hope this helps!
-Mike
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 10-02-2016, 07:10
mrnoble's Avatar
mrnoble mrnoble is online now
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Let's say you only need a few custom gussets, and you don't have access to a CNC, water jet, or other machine shop. Here's what my team has done.
-CAD the part.
-print a 1:1 drawing (full scale, in other words) onto paper.
-using spray adhesive, attach the drawing to a piece of sheet metal.
-cut out the part carefully on a bandsaw.
-sand and file the edges.
-using an automatic center punch, line up the holes.
-drill out the holes using a drill press.
-remove the paper and clean the part.
http://www.angelbotics.com
Remember why you're doing this.
Unread 10-02-2016, 07:12
Gdeaver Gdeaver is offline
FRC #1640
This year we are cutting gussets on a X-Carve CNC router. 500mmx500mm unit. Bought a base kit and sourced other components to keep the cost down. Have about 700$ plus some end mills in it. Took some time to learn the process to get good cuts. It's great for making gussets. Our side plates for the tank drive module were done by water jet. Even if our router was big enough to do the side plates it would have taken for ever. We model in solid works. We have been going Solid Works -> Inkscape -> Easel for the software. If we had time to master it we would have used HMS express.
Unread 10-02-2016, 07:16
-CAD the part.
Great advice!
My only suggestion, drill the holes first. Generally, for a gusset, it's the holes that really matter. Doing the holes first means that, if you mess up, you waste less time making a new one. And we all know there will be mess ups
-Mike
Unread 10-02-2016, 08:14
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
If a drill press is your only tool, you can use 0.1" perf board as a template, at least for right angles (you can also use it for 37/53 degree angles, you know a 3-4-5 right triangle). Mark the holes you're going to drill, clamp, and match drill 1/16" pilot holes using the perf board, remove the template, then follow up with your rivet/bolt size. I've also used this trick for laying out control panels and LED arrays - nice even spacing with little fuss.
Unread 10-02-2016, 08:29
Nebster's Avatar
Nebster Nebster is offline
AKA: Ben Kishter
FRC #1306 (BadgerBOTS)
Nebster is an unknown quantity at this point
Have you been cutting aluminum on the x-carve? How is that working for you?
2015 Wisconsin Regional Chairman's Award - Carson Division
2013 Wisconsin Regional Chairman's Award - Curie Division
Unread 10-02-2016, 08:30
Back after 4 years off
FRC #5279
Clever, definitely adding this to my bag of tricks.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 10-02-2016, 09:12
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
We use CAD, dial calipers, a band saw, center punch, and drill press. It is not a fast process, but it is successful about ~70% of the time for simple parts like this, and give our students some good experiance.
Unread 10-02-2016, 09:35
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
This is, in my opinion, one of the big drawbacks of pre-machined holes in parts. It's rather time consuming to get everything to lineup properly when you have to make anything custom to interface with it. It's probably the biggest reason my team has moved away from pre-machined holes. Everything we use is simple extrusion, then you just clamp your gusset on it, drill a couple holes through both pieces at the same time, and bolt/pop rivet it in place. Your holes always line up that way, and if you want a nice clean look you just need to properly mark your spacing on the top piece before you drill.
2016: Lake Superior WFFA
Unread 10-02-2016, 09:42
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
We get some free waterjetting through one of our main sponsors, Caterpillar. However, the slow turnaround time for waterjet can be very limiting. We recently got a very simple (and very unforgiving) tabletop sheet router, for doing quick mockups and prototypes. It's very sensitive to calibration, and basically everything else, and it isn't nearly as accurate as waterjetting. However, it's nice to be able to whip up a custom gusset out of MDF in a matter of 10 minutes, to make sure it fits the way it should.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 10-02-2016, 12:25
FRC #1640
We have been cutting .125 Al 6061T6 on the X-Carve. It does take some dialing in to cut AL. We need to do some mods to be able to cut faster or with more precision. For gussets it's fine. For real precision we need to go to true cam software. Something to master after the season.
