Go to Post In FIRST, you can either have comfortable safety margins or you can have a competitive robot, you can't have both. - Joe Johnson [more]
Unread 10-02-2016, 11:37
Caboose's Avatar
Caboose Caboose is offline
Programmer - LabVIEW, C++, C#, Java
AKA: James Parks
FRC #0900 (Zebracorns)
Caboose has a spectacular aura aboutCaboose has a spectacular aura about
Smile Re: NAVX Libraries
Originally Posted by pribusin View Post
We are trying to use the Navx board in LV for gyro angle controlled driving in auto mode. We're having difficulties talking to the Navx board in general. One item of difficulty is how to make available the Navx libraries in LV. Last night we looked at the example code and cut & pasted the open part into the begin.vi and the read part into teleop.vi but got no response. Are we missing a step somewhere? One thing i noticed is the DevRef naming appears different than what we're used to with the WPI library functions. Not sure that has any bearing on it. Any help is appreciated.
Did the example code work and yours not? What do you mean by "make available the Navx libraries in LV"? Are you adding the library file to your project? Do you have the latest version of the library (v2.0.4.0)? What interface are you using for communications? Although I tried to make things similar, the LabVIEW library for the navX is not a WPI library.
Originally Posted by Greg McKaskle View Post
The team I'm helping with found that they had old firmware on their navX. The board works much better with newer firmware. But we are seeing a crash issue on subsequent interactive deployments.
Greg McKaskle
That's odd...logs? What type of crash? Are you using the stop VI in your finish? What interface are you using for communications?
navX Labview Library
"Robots are aluminum shavings, held together by zip-ties."
myManga
