Go to Post i do not TOUCH the robot. i don't even press the load button or the reset button. nooo touchy. but i like it better like that, this way, when something goes wrong, i can wholly blame the electronics ppl - nehalita [more]
Unread 10-02-2016, 10:43
michael5402 michael5402 is offline
FRC #5402
michael5402 is an unknown quantity at this point
Mounting Bumper
My team is looking for the best way to mount bumpers on our robot.
Unread 10-02-2016, 10:45
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Re: Mounting Bumper
We are going to use quick disconnect pins. With C channel on the robot and L bracket on the bumpers.
We are doing reversible bumpers anyway but, we figured it would be nice to be able to remove them with ease.
Unread 10-02-2016, 11:23
FRC #5402
Re: Mounting Bumper
If you have a mount for your bumper, mounted to your frame does that count towards your perimeter?
Unread 10-02-2016, 11:35
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Mounting Bumper
That's how I understand it.
Minor protrusions no greater than 1/4 inch such as bolt heads, fastener ends, and rivets are not included.
Also, if you want more useful suggestions, it would help greatly if you would add some pictures of your robot. I would make bumper mounts in different ways, depending on what the robot has in the area where the bumpers will attach.
Unread 10-02-2016, 12:45
FRC #5402
Re: Mounting Bumper
This is the only picture I have right now
Unread 10-02-2016, 12:49
MrForbes's Avatar
AKA: Jim
Re: Mounting Bumper
It looks like you're going to have to add some parts to the sides of the robot, to support the bumpers (see R26 for details).
Unread 10-02-2016, 12:55
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Re: Mounting Bumper
And it looks the arms of your external boulder collector will only be able to stop at a point 9" from the ground (to rest on top of bumpers if they start 4" from the floor) at the front of your frame if you don't have 8" of frame on each segment outside of the collector arms to fit legal bumpers in the front.
"A genius is just a talented person who does his homework" T. Edison
Unread 10-02-2016, 12:58
Josh Drake's Avatar
Josh Drake Josh Drake is offline
Engineering Mentor
FRC #5403 (Aluminosity)
Josh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond repute
Re: Mounting Bumper
Wheel diameter looks to be more than 8", so you would have to make a structure on the outside of the wheels in order to support at least every 8". That could be attached to the front and back and then add a support or two in the middle. If you went with just covering the 8" on the corner, you could have a support just behind the wheel, but I believe you still have to add a structure.
07'-10' FRC 343
11'-12' FRC 2751
13'-14' FRC 3494
15'-16' FRC 5403
Unread 10-02-2016, 13:18
FRC #5402
Re: Mounting Bumper
We are planning to inclose our wheels
