Go to Post It's over, done, let's move on and be positive. Next year maybe everything will be perfect. :cool: - Ed Sparks [more]
Unread 10-02-2016, 15:30
Re: Encoder help
Originally Posted by Mitchell C View Post
elaborate please, why wouldn't you use it for drive train, also it's kinda all we have available.
Because it's an absolute encoder. It measures angles from 0 to 360 degrees.
Unread 10-02-2016, 16:07
Mitchell C Mitchell C is offline
FRC #0313
Mitchell C is an unknown quantity at this point
Re: Encoder help
Thank you, this solves a lot of problems.
Unread 10-02-2016, 17:15
mmaunu's Avatar
mmaunu mmaunu is offline
FRC #2485 (W.A.R. Lords)
mmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the rough
Re: Encoder help
If you can, I would urge you to do as Ether says and get an incremental encoder. We love these from US Digital:
http://www.usdigital.com/products/en...tary/shaft/S4T
(Well, we actually use the older S4 line, but they are kind of discontinued [you can order them if you call them up, but they are encouraging new customers to move away from the S4s]. The S4T seems to be the successor to the S4.)
We get them configured as single-ended with bearings. They are not cheap, but they are great!
EDIT: DO NOT USE THESE FOR YOUR DRIVE TO MEASURE DISTANCE. SEE ETHER'S POST BELOW.
If you need to, you can use the MA3 (which are also great encoders...but trickier to use in this scenario). We have used MA3s to maintain state for a shaft that has multiple rotations by creating a wrapper class with an MA3 field. The wrapper class maintains a separate position variable (a double) that gets updated based on a delta we acquire from the MA3. Basically, as the data from the MA3 changes, we calculate the change from the last reading to this reading, and then we update the separate position variable in this class. You should be able to map the value of this separate position variable to distances traveled.
Here's some (Java-esque) pseudocode.
class MA3Wrapper implements PIDSource {
  MA3 ma3;
  double position, lastMA3Value;
  void updatePosition() {
    double currentMA3Value = ma3.get();
    double delta = currentMA3Value - lastMA3Value;
    //the reality is that the delta calculation is complicated by the wrap-around
    //behavior of the MA3, but you can figure it out...left as an exercise for the reader?
    position += delta;
    lastMA3Value = currentMA3Value;
  public double pidGet() {
    return position;
With something like this, you would call updatePosition() periodically (in a separate thread or from teleopPeriodic() and autonomousPeriodic()). You could use the wrapper as a PIDSource for a PIDController object. Again, this is Java-flavored but I believe that a C++ implementation would have similar elements.
You will have to map the position variable to some real-world distance to make it meaningful, but you will have to do something similar to give meaning to an incremental encoder's count as well.
Lastly, if the encoder can turn more than half a revolution between updates, then your position will get off. That might make it a deal breaker in this case depending on what shaft you monitor. It should be fine if you monitor one of your wheel's shaft.
Hope it was helpful and not just some incomprehensible wall o' text.
TL;DR It's doable with an MA3, but it would really be better to get a good incremental encoder.
2014 Las Vegas (Winners with 987, 2478; Excellence in Engineering)
2014 San Diego (Finalists with 987, 3250; Quality Award)
2013 Inland Empire (Winners with 1538, 968; Excellence in Engineering Award)
2013 San Diego (Finalists with 2984, 4322; Creativity Award)
2012 Las Vegas (Finalists with 2034, 3187; Quality Award)
Unread 10-02-2016, 18:14
Re: Encoder help
Per the datasheet, max rpm for MA3-A10-250-N is 100 RPM.
Unread 10-02-2016, 19:02
mmaunu's Avatar
Re: Encoder help
We'll that is incredibly relevant. Edited the post to reflect the fact that this will not work. We did the above to maintain the heading on some swerve modules over the summer, which worked out, but I'm now wondering if we should look at limiting the heading's rate of change.
As always, thank you.
Unread 13-02-2016, 13:14
CHenry18 CHenry18 is offline
FRC #2874
CHenry18 is an unknown quantity at this point
Re: Encoder help
Hello,
Can the Talons sr have encoders on them (not the talonsrx). If they can what do I need to buy?
