Go to Post It's not easy dealing with the reality that others aren't as passionate as we are and that the process may be slower than we want it to be - but it gives me plenty of time to think and prepare. - JaneYoung [more]
Unread 10-02-2016, 17:20
Joining the 900 Meme Team
FRC #0079
Re: Longer Talon SRX Data Cables
I was actually just talking to John Novak about this earlier this morning. From what he was saying, it's a bad idea to extend them you're better off running the encoder cables back to the breakout board.
Hopefully Omar can hop in here and verify this.
Unread 10-02-2016, 17:51
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Another possibility is to relocate the SRX closer to the sensor. Unless the sensor is far away from the route from the PDP to the motor, it may reduce wire losses overall.
Unread 10-02-2016, 19:30
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
I've been emailing back and forth with Paul Copioli on this exact topic.
What I was suggesting was that Cross The Road make female breakout boards that can plug directly into the SRX and encoder so that we could solder our own wires between the two without the need for a ribbon cable. Paul, as I understand it, was thinking people would just make their own ribbon cables. I've suggested they publish a list of parts and a Youtube video for doing that because my previous experience with making my own 30 gauge ribbon cables has not been a positive one.
Unread 10-02-2016, 21:51
staplemonx's Avatar
staplemonx staplemonx is offline
The Idea Guy
AKA: JJ Biel-Goebel
FRC #1389 (The Body Electric)
staplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond repute
We have extended them just fine with the digi key cables recommended in another thread http://www.chiefdelphi.com/forums/sh...d.php?t=143159
crazy engineer
www.jjbiel-goebel.com
helping team 1389
http://team1389.com/
Unread 10-02-2016, 23:18
Sparky3D's Avatar
Sparky3D Sparky3D is offline
AKA: Dustin D
FRC #1736 (Robot Casserole)
Sparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of light
We made our own ribbon cables with this cable and these connectors. It's the first time we've tried to make ribbon cables, but it turned out to be really easy. We've done some preliminary testing on the robot and everything is working fine so far.
Unread 10-02-2016, 23:55
Dale's Avatar
Head Coach & Mentor
AKA: Dale Yocum
Did you just use a vice to clamp the connector or use some other method? 30 gauge wires just seem tricky to hit but maybe I'm over thinking it.
Unread 11-02-2016, 10:59
Sparky3D's Avatar
AKA: Dustin D
We just used a mini vice with flat jaws. The connectors have grooves for the wires, so it was pretty easy to get things aligned properly and crimped.
Unread 11-02-2016, 11:18
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Omar and Mike... you're both getting bright pink t-shirts that say "I like ribbons" if 900 gets back to St Louis again this year. I love these encoders but I hate these cables.
Unread 13-02-2016, 15:24
juchong's Avatar
juchong juchong is offline
Electrical Engineer
AKA: Juan Chong
FRC #2655 (Flying Platypi)
juchong is a jewel in the roughjuchong is a jewel in the roughjuchong is a jewel in the rough
The ribbon cables aren't my preferred choice, but they work.. We just extend the wires connected to the breakout boards and use the ribbon cables sold on the CTRE website.
Teams I've worked with:My Website: http://www.juanjchong.com/
What I do: Analog Devices iSensor Product Engineer
Unread 17-02-2016, 09:54
Allthatslack Allthatslack is offline
None #1389
Allthatslack is an unknown quantity at this point
Hello 1389 here,
We have been ditching the short data cables and we are now using this ribbon cable: http://www.digikey.com/product-detai...100-ND/3867658
And these ends: http://www.digikey.com/product-detai...645-ND/3883465
Just make sure that you orient the ends the same way that the data cable ends are or else the encoders will not get power. (We went through a lot of debugging before we figured this out)
Hope this was helpful
