Go to Post ...if most of the money comes from sponsors, I have a bit of a problem letting them [the students] charge off a cliff with it. - TimCraig [more]
Unread 09-02-2016, 17:49
Team 5706 Team 5706 is offline
FRC #5706
Team 5706 is an unknown quantity at this point
Exclamation Seeking Help for Programing!!!
The lead programmer in our team has left us, we are left without very much knowledge on the programming front. Just contact us at our email newberryarearobotics@gmail.com Please help, thank you for your consideration.
EDIT: we are using labview 2015
Unread 09-02-2016, 17:50
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Seeking Help for Programing!!!
What language are you guys using? Do you have any code already developed? Previous years code?
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 09-02-2016, 18:00
tomer tomer is offline
FRC #4590 (GreenBlitz)
Team Role: CAD
tomer is an unknown quantity at this point
We will be glad to assist you (we are programming in C++)
Please give us some more information, do you have any programmers left? What do they need help with?
Greeting,
Tomer from GreenBlitz 4590
Unread 09-02-2016, 18:09
FRC #5706
We are using English as our main language.
I am just kidding, we are using LabView 2015, we have no code for this years competition. We do have last years code, however we are using a tank drive this year whereas last year we simply used wheels. Thanks for the help!!
Unread 09-02-2016, 18:20
AKA: Matt B
FRC #1771 (1771)
Although I can't help with LabView, what do you mean by tank vs wheels? Did you do arcade drive last year (1 joystick to translate the robot around the field)? Or 2 joysticks?
Do you mean you're using tank treads?
1771- Mentor (2015)
Unread 09-02-2016, 20:23
Karel_4481's Avatar
Karel_4481 Karel_4481 is offline
When it gets tough bring the Dutch
AKA: Karel van de Vrie
FRC #4481 (Team Rembrandts)
Rookie Year: 2015
Karel_4481 will become famous soon enoughKarel_4481 will become famous soon enough
What are you guys planning on doing this year?
And how far do you want to take everything? Think about:
- Autonomous
- Feedback loops
- Controls
- How many sub systems
Because it is very easy to just use the standard project FIRST gives you with some minor tweaks. But building complicated systems will take time and testing which is difficult when living in different timezones.
Edit: we are using labview so I could help when I have time.
Unread 10-02-2016, 09:15
jojoguy10's Avatar
jojoguy10 jojoguy10 is online now
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
jojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant future
Out team programs in LabVIEW as well, and when I was training our new students, I had them read this book: http://www.chiefdelphi.com/forums/sh...book+labv iew
It was very useful for me and I learned some new things.
2013 and 2014 - Student (FRC#2990), Programmer (LabVIEW)
2015 and 2016 - Mentor (FRC#2990), Programming (LabVIEW)
2017-Current - Mentor (FRC#997), Controls/Programming (Java)
2015-Current - A/V Volunteer at Oregon events
Unread 10-02-2016, 17:22
FRC #5706
Yes I mean tank treads and I believe it was two joysticks. Sorry for the miscommunication.
Unread 10-02-2016, 17:24
FRC #5706
Thank you for your help, i will definitely look over this book!
AKA: Matt B
FRC #1771 (1771)
If you used two joysticks to translate the robot about the field (and presumably a third joystick for the 2nd driver), you used what is called "tank drive". This means that the left joystick controlled the wheels on the left side of the robot, and the right joystick controlled the wheels on the right side.
Your code for driving will be almost the exact same as with tank treads.
1771- Mentor (2015)
