Using Built-In Switches on Linear Actuators
Short problem description: Is it legal to use the built-in limit switches of aftermarket linear actuators?
Longer, more detailed description: We bought a linear actuator not realizing that the motor it had on it would be illegal for FRC use. We switched the motor with an AndyMark 9015, making it a viable power source, but we wired it through the body of the linear actuator, which contains circuitry for limiting the travel of the actuator. According to R55, "Custom circuits shall not directly alter the power pathways between the Robot battery, PDP, motor controllers, ... or other elements of the Robot control system." Does this mean that using the built-in limit switches of the actuator between the motor controller and the 9015 is illegal? If anybody can provide any information/clarification on this issue it would be greatly appreciated! |
Re: Using Built-In Switches on Linear Actuators
I think I would consider that to be modifying the power pathways.
HOWEVER, there would also be a legal way to do this: Wire the limit switches to the RoboRIO (or speed controller limit switch ports) and the motor to the speed controller in question, then program the RIO to react appropriately when a limit switch is pressed. |
Yes that would be illegal.
My recommendation is just to modify it so you can use normal stranded wire connected directly to the motor. |
Can you go a bit more in depth about that linear actuator and motor illegalness? We just ordered some actuators.. |
We can't just buy any motor or device with an incorporated motor that we want and use it on our robots.
The only legal motors are listed in Table 4-1: Legal Motors on page 20 of the Game Manual Robot section. In general, for actuators that we purchase on the open market, the motor it comes with will not be on the Legal list and will have to be removed and replaced with a legal motor. |
#7
Perfect. We are in the exact same boat, so it's time to rip those motors off and slap some 9015's on them.
