Go to Post Oh yes - and thanks for giving us kids our dreams. - DonRotolo [more]
Unread 09-02-2016, 00:48
Holo3453 Holo3453 is offline
Drive Coach, Electrical Director
FRC #3453 (DEM BOTS)
Rookie Year: 2015
Holo3453 is an unknown quantity at this point
Difficult Battery Connectors
The connectors on our battery have become extremely difficult to disconnect. We tried adding little "hooks to grab on to get a better finger position, but they just made it more difficult.
Any suggestions on how to make the batteries easier to disconnect?
Unread 09-02-2016, 02:16
Bruceb's Avatar
Bruceb Bruceb is online now
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Re: Difficult Battery Connectors
dielectric grease
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 09-02-2016, 06:21
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
One of our students came up with a device that made separating the battery connectors easier. It looked like a nut cracker but had two pins, one on each arm, not far from the pivot. The pins were inserted into the small through-holes in the mated connector pair with one pin in each connector. Opening the two arms separated the connector with about a 3:1 leverage advantage.
The tool has since gone missing but the connectors have loosened up enough to be separated by mere mortal hands (barely).
Unread 09-02-2016, 07:24
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Check the pins in the connectors. Bent and warped pins are harder to disconnect. We have a few like this in our inventory and I'm thinking about cutting them off and crimping on new pins.
Unread 09-02-2016, 08:55
ILAMtitan ILAMtitan is offline
Texas Instruments
AKA: Bart Basile
FRC #3005 (RoboChargers)
ILAMtitan will become famous soon enoughILAMtitan will become famous soon enough
Anderson's use spring tension to push two flat contacts together. This ensures that you have a solid connection which can carry the requisite current and not fail on you. As a result, it takes about 15lbs of force to pull them apart. A solution to make it a bit easier is to mount the robot side of you connector to a rigid surface, not just leave it dangling.
Unread 10-02-2016, 19:19
An easy way to separate these connectors is to grasp one side in each hand and bend the connection in the plane of the connector such that one terminal pulls apart before the other terminal. This gives you half the force to separate that both contacts together. It will take a little practice but it does work.
Another method is to take a piece of 1/8" nylon rope (or larger) and thread and tie it through the open holes in the connector. This will give a larger pulling area for smaller hands. This method is often employed in UPS batteries that use the same series of connector.
As pointed out by Bart above, the spring tension and pin alignment is part of the mechanism that allows these connectors to meet current and series resistance specs. Do not make changes in either. Local heating, connector damage and melted components may result. The inspection staff at events will send me a few pictures of connectors that are damaged in this way every year.
Unread 10-02-2016, 19:53
indieFan indieFan is offline
RoboDox and LVHS - Missing you!
FRC #5941
indieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond repute
I'm trying to visualize this and think it's the following:
1. Grip one side in each hand.
2. Hold wide flat of Anderson parallel to floor.
3. Rotate hands toward or away from stomach (for reference) keeping wide flat of Anderson parallel to the floor.
Is this correct?
Unread 11-02-2016, 01:05
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Is this correct?
Yes, this is how we separate them. It will disengage one contact at a time. Of course, you should be pulling the two housings apart continuously as you do this.
Unread 11-02-2016, 01:46
Knufire Knufire is offline
http://www.powerwerx.com/powerpole-a...andle-kit.html
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 11-02-2016, 01:51
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
FRC #4607 (C.I.S.)
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
Sounds like the makings of a great product to sell to FRC teams... just like the LEGO Brick Separator is for those of us with no fingernails to speak of (and love LEGO). IDK - may be a good way to subsidize the costs of an FRC season.
"An error does not become a mistake until you refuse to correct it" ~JFK
Unread 14-02-2016, 01:23
The connectors on our battery have become extremely difficult to disconnect....
I notice that many of the pink-colored SB-50 connector assemblies in the Kit of Parts the past two years have that problem. The ones I've looked at came with the "high-detent" connectors that are designed to be difficult to disconnect. Put two of them together and it's nearly impossible to separate them without applying force that almost seems to risk breaking them.
We avoid using those connectors. If necessary, we would put one on a battery, but never on a robot or charger. We rely on other means to keep the connectors from coming loose during a robot match.
