Go to Post Our prototypes are good and running, now just need to do some magic to transform all that wood to aluminum. :eek: - FIRSTMa2104 [more]
Unread 10-02-2016, 12:38
fireXtract fireXtract is offline
MegaHertz_Lux
FRC #2847 (Mega Hertz)
fireXtract is an unknown quantity at this point
GRIP errors
I have tried to get grip working with my axis camera. It is setup at "axis-camera.local" on my roboRIO and the new radio. GRIP works on the computer(I can see the camera and all the functions dont have red triangles) but when I deploy it to the roboRIO i get lots of errors!
/usr/local/frc/JRE//bin/java -Xmx50m -XX:-OmitStackTraceInFastThrow -XX:+HeapDumpOnOutOfMemoryError -jar '/home/lvuser/grip.jar' '/home/lvuser/project.grip'
Loading Dependency Injection Framework
Feb 10, 2016 5:39:55 PM java.util.logging.LogManager$RootLogger log
CONFIG: Configuration done.
CONFIG: GRIP Version: 1.2.0
platform: /Linux/arm/
Feb 10, 2016 5:40:00 PM edu.wpi.grip.core.Main start
INFO: Loading file /home/lvuser/project.grip
Feb 10, 2016 5:40:02 PM edu.wpi.grip.core.operations.composite.PublishVideoOperation lambda$new$33
INFO: Starting camera server
Feb 10, 2016 5:40:02 PM edu.wpi.grip.core.Main start
INFO: SUCCESS! The project is running in headless mode!
Feb 10, 2016 5:40:02 PM edu.wpi.grip.core.PipelineRunner$1 startUp
INFO: Pipeline Starting
OpenCV Error: Assertion failed (ssize.area() > 0) in resize, file /home/javacpp-presets/opencv/cppbuild/linux-frc/opencv-3.0.0/modules/imgproc/src/imgwarp.cpp, line 3208
Feb 10, 2016 5:40:02 PM edu.wpi.grip.core.Step runPerformIfPossible
WARNING: The Resize Image operation did not perform correctly.
java.lang.RuntimeException: /home/javacpp-presets/opencv/cppbuild/linux-frc/opencv-3.0.0/modules/imgproc/src/imgwarp.cpp:3208: error: (-215) ssize.area() > 0 in function resize
	at org.bytedeco.javacpp.opencv_imgproc.resize(Native Method)
	at edu.wpi.grip.core.operations.composite.ResizeOperation.perform(ResizeOperation.java:88)
	at edu.wpi.grip.core.Operation.perform(Operation.java:61)
	at edu.wpi.grip.core.Step.runPerformIfPossible(Step.java:139)
	at edu.wpi.grip.core.PipelineRunner.runPipeline(PipelineRunner.java:196)
	at edu.wpi.grip.core.PipelineRunner.access$200(PipelineRunner.java:32)
	at edu.wpi.grip.core.PipelineRunner$1.runOneIteration(PipelineRunner.java:76)
	at com.google.common.util.concurrent.AbstractScheduledService$ServiceDelegate$Task.run(AbstractScheduledService.java:189)
	at com.google.common.util.concurrent.Callables$3.run(Callables.java:100)
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
	at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
	at java.lang.Thread.run(Thread.java:745)
Feb 10, 2016 5:40:02 PM edu.wpi.grip.core.Main onExceptionEvent
SEVERE: The Resize Image operation did not perform correctly.
WARNING: The HSV Threshold operation did not perform correctly.
java.lang.IllegalArgumentException: HSV Threshold needs a 3-channel input
	at edu.wpi.grip.core.operations.composite.HSVThresholdOperation.perform(HSVThresholdOperation.java:71)
SEVERE: The HSV Threshold operation did not perform correctly.
Feb 10, 2016 5:40:03 PM edu.wpi.grip.core.Main onExceptionClearedEvent
INFO: Exception Cleared Event
Feb 10, 2016 5:40:03 PM edu.wpi.grip.core.operations.networktables.NTManager lambda$new$16
INFO: NetworkTables: Dispatcher.cpp:392 client: CONNECTED to server 172.22.11.2 port 1735
My common sense would make me think that the camera isn't displaying frames, but I can clearly see the feed from the camera on my computer when plugged into the roboRIO via usb or the wireless radio! Has anyone else had a similar problem? Any advice on what to try?
Unread 10-02-2016, 19:07
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: GRIP errors
Deploying GRIP currently does not work with axis IP cameras.
Unread 10-02-2016, 22:25
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
Re: GRIP errors
It's possible that that could happen if GRIP can't connect to the camera, although in that case I think you would also get a "Connection refused" error.
Can you check if you can ping the camera from the roboRIO?
GRIP (Graphically Represented Image Processing) - rapidly develop computer vision algorithms for FRC
Unread 11-02-2016, 10:51
MegaHertz_Lux
Re: GRIP errors
I'm on my phone right now, but I'll check for the ping later. If the grip is getting refused by the axis Camera what can I do to fix that? Do I need to sign into the camera and add an lvuser profile to the access? I already have the anon login enabled, but does it need a different type of access? Should I set the camera to a static IP? Right now I use mDNS.
Unread 11-02-2016, 10:55
FRC #0237
Re: GRIP errors
If it works on the desktop, it's probably not an authentication problem. More likely just an issue with the network setup, although the particular stacktrace you got is kind of weird for that sort of problem.
Unread 11-02-2016, 12:41
MegaHertz_Lux
Re: GRIP errors
Well I can in fact ping the ip camera from the PC while connected through wifi and roborioUSB. I changed the setup to use the static IP i assigned through the GUI of the camera(10.28.47.10) and I tried just running a GRIP that all it does is PUBLISH VIDEO and it still errors out.
