Go to Post Ancient doesn't necessarily mean bad, but ancient things do fall out of use, otherwise I'd be tapping this out in morse code or writing it in Latin. - Greg McKaskle [more]
View Poll Results: How heavy are you?
So light we'll be flying around the field 12 7.19%
<80 16 9.58%
<90 40 23.95%
<100 37 22.16%
<110 31 18.56%
<120 24 14.37%
>120 7 4.19%
Voters: 167. You may not vote on this poll
Unread 10-02-2016, 23:39
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Re: How heavy are you?
OP, I think what you're noticing is also a side effect of coming off of a year with significantly larger robots. Sure, the 120" frame perimeter isn't really that much smaller, but with extension limits and whatnot, and with so many teams going for the low bar, robots will be smaller, and in turn will weigh less.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 10-02-2016, 23:53
EricH EricH is online now
Our practice bot went on the scale a while back with as much stuff as we thought was going on it.
Let's leave it at one of the topics of discussion over the next day or so was places to lose some weight. Not over yet, but close enough to be a bit nervous.
Unread 11-02-2016, 00:09
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I guessed...but I suppose we ought to weigh it, one of these days! Although we haven't put much weight into the robot. A couple pieces of 3/8" plywood, a miniCIM, a P71/775, two pieces of ABS pipe, a little plywood for electronics, a few sections of 2x4, and a little bit of skinny steel strap...all this added to a kit chassis with two extra kit wheels. Not the makings of a heavyweight.
Unread 11-02-2016, 00:19
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We were well under 80# at our last build session, excluding battery and bumpers. This did not include our top shielding, including the portcullis/low bar deflectors which should be about 5#. Several of the parts were not attached, just placed on top, so a few more fasteners and some wire will be added. We did include a solid aluminum belly pan. I marked under 90#. We'll see how we drive over the defenses with all the manipulators and bumpers in place before we decide if we'll run light or add weight down low, and possibly change our gearing to be faster. (We're currently at 5.6 fps adjusted, with easy options to go to 8.4, 8.5, or 12.7).
Edit: Looking at the poll results, this does line up with what you'd expect from limbo capable, high ground clearance robots, especially if they're going to be narrow enough to challenge or scale the tower. Many teams can only pack so much gear into that window.
Unread 11-02-2016, 00:21
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Both the robots I've worked on this season are insanely lightweight. Perses was about 73lbs without battery or bumpers, and 2667's robot is looking like it might be even lighter. We've even started talking about testing adding weights in different locations to help get through obstacles and avoid tipping.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 11-02-2016, 01:18
TCMJ1816's Avatar
TCMJ1816 TCMJ1816 is offline
Peter
AKA: Peter Hartnett
FRC #1816 ("The Green Machine" (Alumnus))
TCMJ1816 will become famous soon enough
We are looking like we will be right about 80# without battery and bumpers. Right now we will be fairly back heavy so we will likely add 30# of steel ballast. Ideally we will use that weight to add a climber between events.
To get what you've never gotten, you must do what you've never done.
Unread 11-02-2016, 08:00
trumpthero786's Avatar
trumpthero786 trumpthero786 is offline
What Part of the Sandwich Are You?
AKA: Humza
FRC #2729 (Storm Robotics)
Team Role: Electrical
Rookie Year: 2015
trumpthero786 will become famous soon enough
I foresee us being right at 120 lbs without bumpers. We have many systems to implement and they are all relatively heavy. Storm is always right at the weight limit, so we'll see where we end up. We may have to shave off some metal at the end of week 6.
CLAP CLAP WHOOSH!
2015 - Hatboro Horsham - Quarterfinalist with 272 and 5181 - Entrepreneurship Award
2015 - Seneca - Quarterfinalist with 316 and 5684 - Engineering Inspiration Award
2015 - MAR Championships - 50th Seed - Quarterfinalists with teams 1923 and 11
2016 - Hatboro Horsham - Team Spirit Award
2016 - Seneca - Gracious Professionalism Award
"nice beaver tail"
Unread 11-02-2016, 08:49
Craig's Avatar
Craig Craig is offline
Drive it like YOU BUILT IT!
FRC #4976 (REBELS!)
Craig is an unknown quantity at this point
We're sitting at 90lbs right now also, all in except a scaling mechanism which is in progress.
I am also shocked at how light we are this season, definitely not something I'm used to.
Founding member: Team #4976 GO REBELS!
Spent some great years with #2386
Founding Member: Team #843
Unread 11-02-2016, 09:09
cad321 cad321 is online now
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
Yes last year was a year for heavyweight champions however I was not referring to last year alone. I've been around FRC for 4 years (this being my 5th) and my team has been around for 8 (maybe 9? cant recall). Every single year we have struggled with weight immensely, so being 30lbs under at the moment, with prospects of being 20lbs under is a massive shock to us.
Unread 11-02-2016, 09:37
catacon catacon is offline
FRC #1444 (Lightning Lancers)
catacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to behold
We are currently 81lbs sans electronics and scaling mechanism. This is the lightest we've ever been and we're pretty excited about it!
Unread 11-02-2016, 09:43
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
FRC #4607 (C.I.S.)
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
4607 is under 90lbs right now... but once we have our manipulators on we will be pushing 110lbs.
"An error does not become a mistake until you refuse to correct it" ~JFK
Unread 11-02-2016, 12:15
NShep98's Avatar
NShep98 NShep98 is offline
AKA: Nathan Shepherd
FRC #2079 (4H ALARM Robotics)
Rookie Year: 2015
NShep98 is on a distinguished road
Don't you know it's impolite to ask a lady her weight?
...The robot is a she now.
To answer your question though, we've only hit about 65 lbs at last weigh, though that may have been before the electronics installed, and there have been a few minor additions, but even still it's not likely to get much heavier unless we add weight on purpose.
